Help! Help! Oil drain plug question
For DIYers:
Here are the risks ...
Always use the torque wrench with proper settings. [If you dont, you can potentially ruin the pan (first) and or the drain bolt second]. You can spring a leak even with a new crush washer.
If you do not use a new crush washer, you can develop a leak ... typically it is not a gusher. [no one can claim you will, and no one can say after how many usages you will]. Note probability of a leak is higher if you have 2 or more crush washers ... so make sure you remove the old one. [for me discard].
If it matters, I for one always change the crush washers.... [why... I grew up with diesel car and the fuel delivery system would fail with a minute (undetectable) air leak ... was stranded in a cold winter night for a tiny leak in 0.001cent (currency exchange) part.]
[We are discussing habits and patterns here which are based in personal experience.]
Salim
Salim
You can find paper copies of the Repair Manual coming up on eBay sometimes. I got mine when the RX300 was new.
I got a PDF-on-CD repair manual on eBay a few years ago, and it is not the same as the official version. I've always found the PDF CD impossible to use. There is a search function, but no index.
So, I'd recommend you get a paper copy Lexus RX300 Repair Manual off of eBay. Or, maybe this eBay CD is different http://cgi.ebay.com/ebaymotors/1998-...spagenameZWDVW
Male and female threads have a gap in them. That is how you can spin them on each other with minimal effort.
In scientific terms all materials have elasticity (where they stretch and tend to return back to their original form) this makes metals more elastic than say rubber. All materials have a certain point at which they become permanently deformed .. they do not come back to their original state.
When you torque a nut or bolt, the bolt gets stretched by the groves. The higher the torque the binding force (squeeze) is higher.
Now lets discuss the gaskets and washers ... if you squeeze them too much they may reach their limit and become permanently deformed and no longer have the pliability to from a seal.
The threads of the nut, bolt, pan, thread etc can also be stretched so much that they strip.
The binding force needs to be enough to prevent unthreading (by vibration etc) and not too much to reach the limit of the gasket, threads etc.
Note: The torque based stretch is on the side of the threads. That still leaves a channel for oil leak.
Salim
ps ... I misunderstood the question what vs why. What has been answered.
Salim
Salim
Salim
My pdf file is not user friendly. So maybe we have the same cd lol
I am with Lexmex, it is not so complicated, the crush washer's main function is to stop the leak.
As long as it holds up the oil and allow the owner to loosen the drain plug, who cares about what brand (and the need for the washer if end goals are achieved)?
I had a Mercedes-Benz for many years and they recommended changing the copper oil drain washer at every oil change. The copper washer really did get crushed in usage.
I agree that aircraft maintenance standards are a whole different thing and I have no problem with reusing locknuts, gaskets, etc. If you reuse the fiber oil drain washer for two or three oil changes, you're down to maybe 25 cents per oil change. That's pretty trivial.
I'd be curious what maintenance items (recommended by Lexus and not the dealers) you think are extreme overkill. Much of the forum seems to go for more maintenance (e.g., oil changes at less than 7,500 mi, periodic transmission drain and refills).
I agree with you, however, when was the last time you or any other mechanic or DIY guy used a torque wrench to properly torque the oil drain plug?
Yes, that sounds very much on the extreme, but there is a need to properly secure and use the required materials on aviation, cars, trains, boats etc.
They also have limitations.
Usually you see the jiffy lube or diy or even the seasoned mech go with "good and tight" torquing methods.
Needless to say they limit the usable life of the component they are torquing.
Usually is exceeded in ways inimaginable. You are right; Lexus,Toyo and ALL other manufacturers have to make money somewhere and what better than recommending to change the washer.
But, let me put something else into perspective. Why is it that you change the oil every 7.5K miles on the RX300? Well simply because the manufacturer tell you that is what they recommend. Now, yes, oil is expendable material but so is the washer.
If you never take off the drain plug then the washer can stay put for the life of the component.
You are probably a good mechanic and believe me I understand and agree very much with some of what you said but I find myself dealing with many people that try to cut corners at aviation and auto work and mostly it would not cause catastrophic damage but there is always the "what if".......that I speculate.
What if its an important part? Everything is important.
I hope I sounded like the azz people call me in my job area.
That would mean i am doing my part.
Sorry, but I had to say all of that.
Hi Pocket Tre- I absolutely respect and agree with the reasons for the standards in A/C work. Pretty hard to pull over to the side of the sky if it conks out. I believe in using a torque wrench (I have 5 different ones- I'm a tool freak), but in automotive work, especially in things like changing oil, I have never used 1. I have a very good feel for the amount of torque and do not feel it is necessary on a pan plug. (would never feel that way about a plane) In all the years that I worked in automotive it has only been in more recent years that anyone suggested replacing a pan plug washer unless it was leaking- they were lifetime unless they were overtightened. That is why I prefer copper- it is soft and seals well for a long time if not for life. Not a crush but rather soft solid washer. It will not distort unless overtightened. I have never in my life believed in cutting corners- in aircraft not torqueing every single fastner is cutting corners- in automotive for an experienced mechanic, you know when to and when you don't have to. I would not think of torqueing alternator bolts for example, though torque specs exist for them. My hat's off to you for being a meticulous A/C mechanic. Roger
I am ok with your response, however what happens when you have to replace a..... let's say something like a tie rod or a steering link where the nut has a torque value and a cotterpin? Do you pass on the torque because it has a cotter pin? Do you reuse the cotter pin?
To me, that is also a little extreme for an example, but why is the requirement there?
I rather know and feel secure that my wheels will not fall off at 65 mph on the highway because I know I replaced the only ONCE used cotter pin (.50c)
Yes, nobody can compare the difference of auto and aviation maint. That was not my intent. My intent is to say that regardless of what you are doing maintenance on you should follow the book.
Bicycle is a good example. Do you pressure the tires to the proper value or just to how it feels?
I know..........
You all hate me for this, I do not want to force MY maintenance practices upon you or any one else. Believe me that is not what I am doing.
It is only my opinion. You do the maintenance whichever way you feel is better.
Believe me I do not do everything correctly. We all make mistakes.
Funny note( I did not torque my eng oil filter last time)
The initial question was more to the extent of "what is the rubbery material" that is on the oil plug area... but has turned into should you replace the washer or not. I know that there are certain maintenance items which are excessive or not necessary, but whether the washer is required each change or not, it's less than $1.50/piece, so isn't the cost a moot point? I would be more worried about getting the right filter than a $1 item.
I've been DIY oil change on all my vehicles since 1985 and I have never used a torque wrench, but have replaced the washer each change and have never had any leaks from that area ever. I just tighten to "touch point" and then give it an extra 1/4 turn perhaps.
Torque wrench is a must have tool.
Once you have it and not use it is like ...
You have a folded umbrella in hand and it is raining on you.
Salim
Salim
I know..........
I know..........
alt. bolts (or my oil filter). LOL May all A/C mechanics be as meticulous as you! Have a great life PT!
Pocket Tre- Your response gave me a good chuckle because I have known quite a few A/C mech.'s. As a matter of fact my deceased half-brother spent his life in the profession. No, PT, I own a more than adequate supply of cotter pins and I do use them- I have never reused a cotter pin unless it was an emergency. I do torque whenever I feel it is necessary (with 5 torque wrenches shame on me if I don't), but still don't feel it's necessary to torque
The only reason you feel this way is because you can pull over to the side of the road if any component fail.
I, on the other hand have less chance of having a component fail because I follow the book for ALL maintenance.
Yes, if you fail to torque any of your components on your vehicle, shame on you. You have them torque wrenches and still refuse to use them. That is your prerogative, however, they must look very nice and clean on their display cases.
Just think it over when you strip a nut or better yet snap a bolt and have to tap a new set of threads with your torque wrench sitting just paces away from you.
Torque wrenches is a must, yes, but what good do they do sitting inside the toolbox and not being used.
Salimshah could not say it better. Great post Salim
