Need windshield wipper blade size specs
Does anyone have the specs for the windshield wipper blade sizes for both the front and back windows? I could not find the specs being mentioned any where in the Owner's Manual.
I bought a 2000 RX300 for my daughter yesterday and I have been cleaning it up. I noticed that the front blades (need replacement) have different lengths (the one at the driver-side is 21" long and the one at the passenger-side is 19" long, measured fron tip-to-tip) and the one for the back window is shorter, measured at 17" long.
Arfe these the OEM sizes?
Super Moderator
Although I am not answering your question ..
The OEM inserts are good. [quality of wipe and life]
Salim
Salim
Lex is right, driver's side is 24, passenger's 21 and rear 16 manufacturer's size wise, may not be "actual" length +/- an inche. I've used 24/22/17 and they are fine too. The fronts won't cross with 24/22 and the rear with 17 covers slightly more area. The 16 are just too short.
As for OEM for replacements, I've always used replacements because if I wait for the right time to stock up at Target during clearance, I get a whole blade and holder (not just the rubber insert) for about $5-6. The Lexus original, which is just the rubber is $22.95 and you're using the existing metal insert and holder, which at times might be old already. At $6 for say RainX, the Lexus OEM is not going to last four times longer.
One more thing about OEM inserts ... you should keep track of how the steel reinforcement come out .. they have a curve and you should re-use it exactly as they come off.
Salim
Salim
ToyotaLexus
RX - 1st Gen (1999-2003)
06-20-01 10:15 AM
