Coolant Flush
Does anyone have DIY pics of this task? Also I have a 99 RX300 AWD do I use the Red or Pink coolant from Toyota/Lexus? Done you have to add water to one of them? Is it okay to use the one that is the 50/50 mix? Sorry all the questions. Thanks in advance for any help.
John
John
Super Moderator
This is one I did not too long ago, https://www.clublexus.com/forums/sho...d.php?t=249741
You can use either the Red or the Pink. The red one you have to add water to, but the pink one is a premixed coolant/water. The red one you had 50% coolant and 50% watre.
John
John
Your RX came with Toyota Long Life coolant (red) which is good for 30,000 miles. In 2004 Toyota/Lexus started using Toyota Super Long Life Coolant (Pink) which is rated for 100,000 miles. The super long life is backward compatible so many are using it to replace the long life. It is also pre-mixed and more expensive than long life. Toyota coolants have become so expensive I prefer to use one of the brand name aftermarket red coolants which cost around $5 a gallon compared to almost $20 a gallon for Toyota. Another option is Prestone All Makes and Models. I keep a gallon of this in the garage for topping off the family cars. It makes life a little easier being that our RX has red, our Matrix pink, and our GM orange (Dexcool).
Mikey- My wife's '02 Camry came with the pink SLLC but as my prior post states, I didn't like the stuff so removed it at about 25- 30k. When my DIL's 99RX looked like it had just been poured in at 97k when I changed it (it had never been changed before), that was good enough for me. As a matter of fact I just purchased some red today for my '04 f-150 PU because I was so impressed with it. The Dexcool is the worst junk I have ever seen. I had it in a '95 Eddie Bower PU that I bought new and also a '95 Taurus SE that I bought new for my wife. I took it out of both of them. When I was still working (for county transportation) we had a lot of GM vehicles with it and the radiators sometimes wouldn't last 40k mi. I have been as impressed with the red as I have been unimpressed with Dexcool. I think you probably get what you pay for. ($5 vs $20) As a matter of fact what I purchased today was $23.95 a gallon on coupon and list about $32. for the red- still didn't stop me from buying it.
I didn't mean to infer that the 2 '95 Ford's that we had came with Dexcool, I had added it because it was a "long life anti-freeze". That was before I realized what junk it was. There are still people who love it. Someone once said "there's a butt for every seat". Guess it applies in this case.
Yea Mikey, I realized you weren't advocating using Dexcool. I'm curious what red you use. All anti-freeze has gone through the roof- I assume it is somehow a derivitive of crude oil. The last red I bought about a year ago was $12.95 w/coupon. I was shocked to see even the Prestone's in the $16.- $17. range at WM a while back.
I have to find out the name of the aftermarket red my oil change guy is using next time I get my oil changed. My 01 came with Toyota red when new, then aftermarket red at 30K and 60K, then back to Toyota Red at 90K, then aftermarket red at 120K. I could never tell the difference but I am changing every 30K. Your 100K test may be a better indication. We are only talking $20difference every 30K between aftermarket red and Toyota red so I guess it's not that big of a deal.
The Prestone All Makes and Models looks interesting and is handy to have around for top offs when you have multiple vehicles in the family. I would be tempted to try it for a complete antifreeze change but haven't gotten there yet.
Personally,I think I`ll stick to the Toyota red.RX develops enough other issues on it`s own.At least this is one less to worry about if you stick with the proper coolant.
This "must use Toyota Longlife coolant " is non-sense .
If you read the User Manual, which is Toyota's official doc to recommend what coolant to use, it does not require Toyota branded coolant. It says "ethylene-glycol type...Toyota Longlife or equivalent"
![](http://rx300how2.home.comcast.net/~rx300how2/Pics/anti_freeze/anti_freeze2.jpg)
I am running 50% Prestone, 50% distilled water since last summer, no problem at all and lots of $ saved. I opened up all three drain plugs and get all of old coolant out and the SUV is running 100% non-Toyota coolant for over one year now.
Yeah,the dipstick on the transmission say`s no need to replace fluid.I certainly hope you don`t abide by that one.Basically it comes down to personal preference,If the prestone works for you,that`s all that matters.People swear by the Amsoil trans.fluid,I found it didn`t work to well at all in my RX.
I'm with you, I have 60k on mine and have not changed it yet and it looks like it is brand new. I'm still going to change it soon, but it looks like it has not broken down at all.
Thanks for sharing personal experiences. My post is to make members aware that there are choices officially endorsed by Toyota, applicable in the RX300 model. Some may prefer one brand, some may want to pay less, but the User Manual says non-OEM brand works well.
At the end of the day, most drivers just care 1) warranty is not voided 2) car drives well 3) low maintenance. If one really cares about performance and longevity, a lab test of used coolant is better than eye test because exact chemical composition is evaluated objectively and independently.
PlotPoint
16
12-13-12 09:34 PM
mikevanle
09-23-06 07:08 AM
