oxygen sensor help please
I have a code of p1135. I am going to repalce the oxygen sensor but I am very confused as to which part is the correct one. Sewell has many listed and other sources show different part numbers. These are what I have found.
Toyota 89467-48011
denso 234-9009
toyota 8946741011
toyota 89467-48010
toyota 89465-49075
I need the sensor for a 1999 Rx300. Can someone please help me make some sense of this. Thank You
Sal
Toyota 89467-48011
denso 234-9009
toyota 8946741011
toyota 89467-48010
toyota 89465-49075
Sal
Toyota 89467-48011
denso 234-9009
toyota 8946741011
toyota 89467-48010
toyota 89465-49075
Sal
Toyota 89467-48011
denso 234-9009
toyota 8946741011
toyota 89467-48010
toyota 89465-49075
Sal
Check the threat on gas mileages. Some one mentioned that there are three oxygen sensors - two of which are for air-fuel ratios, I guess. There are several specific discussions (locations and which to replace first, etc.) about the P1135 code in that thread. There is also a thread on P1135 not long ago. It may be helpful to read them before ordering parts, as they are expensive and often not returnable.
Bob- just curious, did they all fail at the same time? I have to say that is pretty low miles for all 3 to fail. The most common failure is the P1135- which designates B1 S1 which is the sensor next to the firewall and the failure for that code is the heater. The car normally runs fine, just a little rough (not much) til it gets warmed a little and goes into closed loop. I am always suspicious when all 3 fail at the same time- that is NOT what I would consider normal. Using a silicon sealant that is not sensor safe will wipe them out in a hurry.
Well, the first two were replaced several years ago by a dealer in Virginia, when the car was still under the basic warranty. I just got the check engine light and brought the car in. This was maybe in the 40-50,000 mile range actually. I guess I don't know they were both bad, but they said they replaced two. I had the car back in less than an hour.
The second event occurred last winter, at a shade under 60,000 miles, and I took it to a Lexus dealer in Florida, since the car was just within the extended warranty I had purchased. The symptom was again just the check engine light. I'm thinking they replaced the rear sensor near the exhaust since they said they soaked the threads in solvent for several hours before attempting to remove the sensor (and thus kept the car overnight).
Since I didn't do the repairs myself, I don't have much more information. Sorry.
Just want to thank everyone for this thread. 2000 RX300 with 84k. Pulled codes 0125 (coolant temp), 1135 (fuel air) and 1130 (fuel air). Ordered denso 234-9009 ($171 shipped from oxygensensors.com) for rear bank sensor. Disconnected battery terminals during install. Replaced sensor and reconnected battery. Check engine light has disappeared (all codes are gone) and car is working just fine. Kudos to all
Just want to thank everyone for this thread. 2000 RX300 with 84k. Pulled codes 0125 (coolant temp), 1135 (fuel air) and 1130 (fuel air). Ordered denso 234-9009 ($171 shipped from oxygensensors.com) for rear bank sensor. Disconnected battery terminals during install. Replaced sensor and reconnected battery. Check engine light has disappeared (all codes are gone) and car is working just fine. Kudos to all ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
A little trouble getting it out. Soaked it for a few days with PB Blaster while I was waiting for the sensor to be delivered. Once I got the 2 halves of the connector apart I just slid the old sensor end thru an offset box wrench, got the wrench on the old sensor and it came right out. The biggest trouble was getting the 2 halves of the connector apart...there is not a lot of room to work...had to separate the connector with one hand which is not so easy.
Whats up all.....
Was wondering if someone could help....
I got an aftermarket O2 sensor or rather, air/fuel ratio sensor without OEM clip. I NEED TO SPLICE into OEM CLIP.
Could anyone let me know what the "Lexus" wires are? There (Lexus) is (2)black, (1)white, and (1) blue...What (2) are high? and what is signal and ground???
2000 Leuxs RX 300; V6...
Thanks for any insight.....
Whats up all.....
Whats up all.....
I looked it up in my CD Service Manual. I don't understand the abreviations, but maybe this will help.
For the "Heated Oxygen Sensor", Bank 1 Sensor 2:
pin 1 color B? HT
pin 2 color L-W? +B
pin 3 color W? OX
pin 4 color BR? E1
Air Fuel Ratio Sensor, Bank 1 sensor 1
pin 1 HAFR (right), color L?
pin 2 color B-R?
pin 3 AFR+ (right), color R?
pin 4 AFR-, color G?
Air Fuel Ratio Sensor, Bank 2 Sensor 1
pin 1 HAFL (left), color G?
pin 2 color B-R?
pin 3 AFL+, color L?
pin 4 AFL-, color B-W?
pin 1 color B? HT
pin 2 color L-W? +B
pin 3 color W? OX
pin 4 color BR? E1
pin 2 color B-R?
pin 2 color B-R?
