Low Speed Brake Squeal, I need advice
hey folks, i am back again, I am working down the list of problems on my new to me ride..so here is my next workorder..
how do i stop that brake squeal at low speed, it happens forward and backwards..
the pads are new from when I bought the unit from the car lot, can you help with a fix?
thanks
jon
thanks
jon
There are probably other solutions, but the stock solution is anti-squeal shims. If you search the forum archives, you will find numerous instructions and diagrams of what they look like and how they are attached. It sounds to me like whoever replaced the pads didn't replace the anti-squeal shims, or didn't put them back correctly. I've wondered if the blue cream that dries to an anti-squeal membrane that I've used on previous cars would work too, but I'll probably never know.
my solution was to grease up every contact point where the pads touched any pad support plates..
now it doesn't squeal or make that clicking sound when brake is engaged..I will see how long this works and probably go do the toyota place and see if i can pick up some new squeal shims..
thanks for your tip..
jon
thanks for the info, you were exactly right! I took off the brakes and there were no anti squeal shims on either side..
thanks for your tip..![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
jon
jon
thanks
jon
Lexus factory pads are good quality ceramic pads made by Akebono. I used them when I did my first brake job at about 70K. My next brake job at about 120K I used Raybestos Quiet Stop ceramic pads. At this point I no longer needed the shims. They seem equally as good.
Buying Akebono aftermarket pads from a discounter like Rock Auto would be another option. They have the wear indicator built in and I don't believe they use the shims. A quick call to a supplier should verify this.
Being that you have new pads, you may want to try some of that squeel stop spray stuff before buying new pads. It is made for pads without shims only and it works more like a glue between the back of the pad and the brake caliper piston.
That would be one option. If you decide to go that route, you can order them online from a Lexus dealer that discounts like irontoad. If you do go back to Lexus pads you will also have to order shims for all the pads and the wear indicator for the one front pad that uses it. Lexus front pads come without a wear indicator. It is a little spring clip that you move over from the old factory pads. The Lexus rear pads have the indicator built in.
very much appreciated.
jon
I know I'll catch some crap for this, but I have been using Autozone's ceramic pads for a while now and I really like them. The shims are already attached to the pads. I don't have those springs either. I just did them for a second time with new Autozone rotors and they look like quality parts and feel great. I used the grease where that PDF calls for it and have had no rattles, squeaks, squeals, etc. They feel awesome and don't seem to make too much dust. With 2 rotors and new pads you are out the door for less than $100 and have free replacement pads forever. Flame away.
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
I know I'll catch some crap for this, but I have been using Autozone's ceramic pads for a while now and I really like them. The shims are already attached to the pads. I don't have those springs either. I just did them for a second time with new Autozone rotors and they look like quality parts and feel great. I used the grease where that PDF calls for it and have had no rattles, squeaks, squeals, etc. They feel awesome and don't seem to make too much dust. With 2 rotors and new pads you are out the door for less than $100 and have free replacement pads forever. Flame away.![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
we all have our preferences and that is ok, but sometimes you need to know what is available, when the money is crunched.. and I just got back from evacuting from the hurricane and my money is tight...
thanks very much for stepping out with this information, it is very appreciated,,you have been a great help to me personally.
thank you for the PM too.
jon
Gillie76
Suspension and Brakes
18
11-05-17 04:50 AM
stlgrym3
04-23-17 08:04 PM
