90k Service - Ripped off or decent
90k Service done at Toyota- Basic 90k - $569.95
Synthetic oil change
Change engine air filter
Replace coolant
Replace iridium spark plugs
Rotate Tires
Drain and refill tranny
Inspect:
Wiper Blades (3 total - 2 front, 1 back) - $40
Timing Belt
1) P/S Fluid
2) Brake Fluid
3) Fuel Injection (every 30k)
Rear Bulb - $3
Drive Belts (2 belts)
Total = $1631.09
Grant total OTD with 15% Discount = $1391
The killer was the timing belt, but it has to be done eventually, right?
I've never had the P/S changed or the brake fluid for that matter so I figured might as well get it done now. It was time for the wiper blades to go, and it was important to me to get the tranny serviced and the iridium plugs replaced (though I know I could have gotten more life outta them)
What's the verdict? Not bad?
Replace coolant
Rotate Tires
Inspect:
Brakes, discs, drums, lines, hoses
Drive shaft boots
Steering linkage
Drive belts
Body and chassis nuts and bolts
Fuel line connections
Exhaust/mountings
Additional Services & CostsDrive shaft boots
Steering linkage
Drive belts
Exhaust/mountings
Timing Belt
Parts - $104.26
Labor - $650
Fluid Changes & Fuel Injection - $278.88Labor - $650
1) P/S Fluid
2) Brake Fluid
Rear Bulb - $3
Total = $1631.09
That is not a bad price. I need my 90k service too and called around to Toyota and Lexus dealerships. Lexus dealers wanted something around $1800 for 90k service and timing belt. Toyota dealers said no they cannot service my RX . Which Toyota dealer did you go to?
The $3 for the rear bulb sounds reasonable. I recently had a stop-light bulb go, and a pair of no-name bulbs at AutoZone was $6.
It sounds like you should have small maintenance bills for a few years now.
Sounds fair for dealer service, definetly cheaper than Lexus. As mentioned above the timing belt does sound high. The Toyota dealer did mine for $399 - 15% parts and labor. Also your plugs wern't due to be changed for another 30K.
Thanks for your opinion, guys. I figured Lex would be more expensive and I could save a bit by going to Toyota. At least I have the peace of mind now and got the "big" service outta the way. I've been doing the minor services myself up to this point - oil changes every 5k, engine air filter, and cabin air filter, IACV fix etc..
Indeed, the timing belt cost was really high. It's $430 at the Lexus dealer here, $370 at Toyota (with coupon) and $350 at an independent. The Lexus worked out to be a better deal for me because of the free Lexus loaner that I needed to get to work quickly.
Also the Iridium plugs don't need to be changed until at 120K. So you got ripped there, too.
Other items seem reasonable for a dealership.
Let's itemize based on individual services at independent shop:
Synthetic oil change $45
Change engine air filter $15 (do it yourself and save $10)
Replace coolant $60
Replace iridium spark plugs (don't need until 120K atleast)
Rotate Tires (ho hum, $20 tops)
Drain and refill tranny $69
Inspect: (all free, the car is up for the oil change anyway, this is all visual)
Drive shaft boots
Steering linkage
Drive belts
Exhaust/mountings
Wiper Blades (3 total - 2 front, 1 back) - $40 (about right, but I do mine for $12 myself)
Timing Belt $350 tops, including labor
Fluid Changes & Fuel Injection - $278.88 (i can live with this)
1) P/S Fluid
2) Brake Fluid (bleeding?)
Rear Bulb - $3 ($1.95 at Walmart, so $3 to do from dealer ain't bad)
Drive Belts (2 belts) $150 parts and labor
So, your real total is about : $1031 from Joe down the road. If you factor that the $1391 includes the spark plugs and a loaner vehicle for a day or two, that's not too bad.
Replace coolant $60
Drive shaft boots
Steering linkage
Drive belts
Exhaust/mountings
1) P/S Fluid
Aftermarket inserts/blades are cheaper, but they don't work as well and last maybe 3-4 months. My Lexus inserts have consistently wiped very clean and lasted about 1.5 years despite the harsh climate here.
Michelin
I pay $32 for 3 inserts at my dealership, so $40 installed is a good ideal IMHO.
my 90k service is coming up too
im at about 88400 right now nearing the 90k. is that what im should be expecting to pay? yikes!
i just did fuel induction/system cleaning for 59.99 at spee dee. ( i gained almost 2 mpgs with no changes in driving habits)
oil change / filter for 29.99 regular pennsoil
front brake pads and rotors re surface 349.99
(didn't need to change the rear ones)
asked my service consultant and said that I can go to 100k with my timing belt. Should i believe him or just change it..
flushing the trannsmission fluild and radiator is up next...
90k?
Belt - fine
Spark plugs - fine
Brake fluid - fine, unless you feel any ill effects
Transmission fluid - fine
Rear diff - fine, you can wait until 100K
