Spark plug replacement
I was trying to inspect / change the plugs the other day and after removing the top cover under the hood, only thing that I came across that was recognizable were fuel injectors. Are the plugs located somewhere else that is hard to reach?
Any help is appreciated.
cy
2003, RX300, 67k miles
cy
cy
cy
Super Moderator
Also I know you have responded to my post about VSC and TracOff light issue and happy to tell you that I have found a posting from another site that solved the problem. The procedure was called something like "way to zero the yaw sensor" or something.
In any case, thanks for all your help!!!!!
Cy
