List of RX300 DIYs
Old 10-31-12 | 06:30 PM
  #31
BearsLexus's Avatar
BearsLexus
Default VVT Solenoid (OCV) Replacement DIY
VVT Solenoid (OCV) Replacement DIY -
Symptoms: Momentary Engine Lag (like a shifting of gears that only lasts 1-2 seconds)
Hard Brakes in the last few seconds of a stop - like stepping on a brick
Low, Rough Idle - feels like it is going to stall
Inability to Use Over Drive - going 65mph with 4500 RPM ... won't shift to lower RPMs
https://www.clublexus.com/forums/rx-...ement-diy.html
bitysmalls (04-20-21)
Old 12-12-12 | 05:17 PM
  #32
hypervish's Avatar
hypervish
DIY Installation of GROM + Bluetooth Dongle
Old 02-04-13 | 09:58 PM
  #33
salimshah's Avatar
salimshah
Front seat & belt buckle (receptacle) replacement:
https://www.clublexus.com/forums/rx-...ml#post7746439
Salim
Old 02-09-13 | 08:53 AM
  #34
hypervish's Avatar
hypervish
Timing Belt Picture DIY :http://diyservice-en.blogspot.com/20...on-1mz-fe.html
Caliper Sliding Pin DIY: http://diyservice-en.blogspot.com/20...ding-pins.html
Note: These are not my DIYs', and I do not take credit for it in any way.
Old 02-11-13 | 06:41 AM
  #35
Dietz's Avatar
Dietz
Lexmex.
is there a DIY on how to replace head lights. I have not seen it on here after looking several times. I tried this past weekend but could not find the last bolt.......plus my fingers froze in the 23 degree weather. I thought I would ask on here before I try again.
Thanks
Old 04-24-13 | 03:49 PM
  #36
hypervish's Avatar
hypervish
Rear Valve Cover Gasket DIY -
Remove Door Panel & Fix Door Handle DIY -
Note: These are not my DIY's, and I do not take credit for them in any way.
Old 05-12-13 | 02:32 PM
  #37
salimshah's Avatar
salimshah
Default Warm-Up cat (pre-cat) between radiator and engine
WU-Cat (pre-cat) for the left side.
https://www.clublexus.com/forums/rx-...u-cat-diy.html
Salim
Old 05-20-13 | 11:00 PM
  #38
gazi001's Avatar
gazi001
How to replace the axle out put seal and axle: https://www.clublexus.com/forums/rx-...iver-side.html
Old 06-02-13 | 01:01 PM
  #39
gazi001's Avatar
gazi001
Here is the DIY for add gps navigation to non navigation RX for navigation, backup camera and Ipod A/V display in the oem gps screen. https://www.clublexus.com/forums/rx-...e-project.html
Old 07-02-13 | 07:45 PM
  #40
imherenow's Avatar
imherenow
easy mod for front and back lights with LED. Now this is on my ES 300 and since its the same layout as RX the setup is same too. makes it much easier too:
https://www.clublexus.com/forums/8020246-post120.html
Sharonika (07-08-22)
Old 10-20-13 | 11:38 PM
  #41
salimshah's Avatar
salimshah
Members, please do not comment on the DIY thread here. Lets keep this thread as an index to DIYs. Post your suggestions/comments/discussion in the actual DIY thread.
Thank you for keeping things organized,
Salim
Old 01-01-14 | 10:32 AM
  #42
M45owner's Avatar
M45owner
FIX FOR FAULTY BRAKE LIGHT FAILURE SENSOR MODULE.
https://www.clublexus.com/forums/rx-...or-module.html
Old 02-08-14 | 07:30 AM
  #43
hypervish's Avatar
hypervish
Found this DIY for Fuel Injector Replacement : http://hubpages.com/hub/DIY-Toyota-M...or-Replacement
Old 04-15-14 | 12:15 PM
  #44
salimshah's Avatar
salimshah
Front struts/shocks
https://www.clublexus.com/forums/rx-...need-help.html
Old 05-13-14 | 08:26 PM
  #45
ATLs460's Avatar
ATLs460
Front Lower Control Arms
[2nd gen RX is different. Please visit 2nd gen forum ... salim]
https://www.clublexus.com/forums/sho...d.php?t=742065
another: added by salim
https://www.clublexus.com/forums/rx-...-arms-diy.html
