List of RX300 DIYs
Old 06-07-16, 05:57 PM
  #61
Drcoffee
Drcoffee's Avatar
Default DIY Battery Ground Cable upgrade
Make an improvement to your charging system with a larger battery ground cable for around $10 in parts. over time the factory battery ground degrades due to acid incursion. Acid Corrosion beneath the plastic sheath prevents proper conduction of electricity and less power to the starter. It can also help with electrical gremlins.
https://www.clublexus.com/forums/rx-...ml#post9512479
Old 06-15-16, 07:46 AM
  #62
Jaycee22
Jaycee22's Avatar
Default Rear Motor Mount Replacement Tips
https://www.clublexus.com/forums/rx-...ml#post9520642
Old 06-23-16, 08:15 AM
  #63
coomassie
coomassie's Avatar
Default Roof Rail Removal
https://www.clublexus.com/forums/rx-...moval-diy.html
Old 07-01-16, 01:46 AM
  #64
gazi001
gazi001's Avatar
Default How To Remove and Installed Heater Core, Evaporator Core and AC expansion Valve
https://www.clublexus.com/forums/rx-...ml#post9538927
Old 11-07-16, 04:57 PM
  #65
salimshah
salimshah's Avatar
Received 1,050 Likes on 948 Posts
Default Coolant thermostat replacement DIY
https://www.clublexus.com/forums/rx-...ml#post9673589
Salim
Old 12-10-16, 03:04 PM
  #66
cwsteini
cwsteini's Avatar
Default Photo DIY: CR2-12V Relay Replacement on Window Control Board
https://www.clublexus.com/forums/rx-...placement.html
Old 05-14-17, 09:55 AM
  #67
Puttster
Puttster's Avatar
Default Replace P0301 ignition coil
https://www.clublexus.com/forums/rx-...oil-p0301.html
Old 11-03-18, 10:29 AM
  #68
vr4/sc400
vr4/sc400's Avatar
Ebay Chinese Door Lock Actuators Tutorial
Old 06-01-19, 10:00 AM
  #69
Nad1370
Nad1370's Avatar
Default FUEL pump replacement
https://www.clublexus.com/forums/rx-...fuel-pump.html
Old 10-20-19, 06:07 PM
  #70
99RX300PDX
99RX300PDX's Avatar
Here is the link to "2000 Lexus RX300 Lift and Support Locations"
https://www.clublexus.com/forums/rx-...l#post10638499
Old 03-02-21, 01:46 PM
  #71
bordenj66
bordenj66's Avatar
Default Alternator fuse replacement
Here is a DIY for replacing a blown alternator fuse.
https://www.clublexus.com/forums/rx-...l#post11004948
Old 03-04-21, 02:47 PM
  #72
bordenj66
bordenj66's Avatar
Default Triubleshooting a particular set of body electrical issues
https://www.clublexus.com/forums/rx-...l#post11006474
Old 04-22-21, 10:35 AM
  #73
maxSteel
maxSteel's Avatar
Door lock actuator
Originally Posted by bitysmalls
I need this DIY!!! Page says no longer active? :/
https://www.clublexus.com/forums/rx-...-write-up.html
Last edited by salimshah; 09-03-22 at 09:33 PM. Reason: Added the title Door lock actuator
Old 05-04-21, 05:48 PM
  #74
bordenj66
bordenj66's Avatar
Default Sunroof drain tube attachment fix
https://www.clublexus.com/forums/rx-...rain-tube.html
Old 09-30-22, 06:06 PM
  #75
Mfrankster
Mfrankster's Avatar
Default 2000 RX300 FWD Engine Replacement and Overhaul
Quick Reply: List of RX300 DIYs
