Bosch Platinum Ir Fusion +4 plugs Part # 4501 issues??
Hi All, I recently replaced old spark plugs with the Bosch and one of you had problems with those.
Has anyone else experienced or noticed any trouble with these plugs?
I have only front three plugs replaced for now without any problem. The car runs well.
Cy
Cy
1 Post
i used those exact same plugs myself, twice actually, for me anyway they run f'n amazing. I noticed a HUGE difference once i put those in. Good luck with doing those back 3. Theres a DIY to help you do those in this forum.
Hey UNOHOO, Thanks for your reply.
BTW, what chage, if anything, that you have noticed after the plug change?
I am glad to hear that, at least, there is no negative result from it. I will tackle the rear ones this weekend.
cy
2003 RX-300, 66K
1998 Chevy Sub, 123k
1997 ES-300, 176k
2007 Acura RDX, 10k
cy
2003 RX-300, 66K
1997 ES-300, 176k
2007 Acura RDX, 10k
1 Post
well before i replaced the old ones with those i was getting poor gas mileage due to the engine missing a lot, i was also getting some shuddering when pulling out or occasionally while driving roughly 55-65 mph, also just idling really really bad, enough to make the engine stall sometimes, granted i had no idea how old the plugs in there were and i replaced the rear 3 coils packs at the same time but i noticed it wasnt missing nearly as much, little bit better on pulling out from a stop and it would coast longer. I changed out the front 3 coil packs a month or 2 later and it got a little better, dont really remember if that shuddering happened after that except when pulling out, ive replaced the MAF sensor and front 2 a/f sensors, plus did another plug change with the same type around the same time as the sensors since the engine was burning so rich. I also switched over to synthetic oil on friday and seriously....my car is running like a dream! im going to use a lot of the DIY guides on here and do my own maintenance on my car and see how far i can push it. Right now ive got 210k and i plan on makin it 350-400k
I run those exact spark plugs right now, I'm at ~140,000 miles and I've had them in there since ~90,000 or less. Pretty good so far, but I think after this I'm switching back over to NGK Iridium's. No reason in particular, just want to try out some new things people have left good reviews about here.
Super Moderator
That's a good point. If you don't modify your vehicle for exhaust/intake like I do, NGK or Denso make perfect sense. Incidentally, I tried the Torquemasters when I had my RX virtually bone stock and I didn't notice much. Took my modifications to really notice a different with the plugs.
