vacuum problem
Old 09-24-08, 05:25 PM
maydneb
maydneb's Avatar
Default vacuum problem
When my car warms up I start to lose vacuum and it starts to idle rough. dose anyone have any suggestions?
Old 09-24-08, 05:47 PM
Lexmex
Super Moderator
Lexmex's Avatar
Welcome to the Club. You can try disconnecting the battery cables for a bit to reset the vehicle's computer and see if that helps, but generally when most of us have had this issue it has been the IACV (Idle Air Control Valve). This is the best thread I have seen on cleaning the IACV valve, https://www.clublexus.com/forums/sho...d.php?t=358579
Another possibility is the MAF sensor. Though generally when this issue pops up, the check engine light comes on, try https://www.clublexus.com/forums/sho...d.php?t=295546 (and see starting at post 7)
Old 09-24-08, 06:39 PM
maydneb
maydneb's Avatar
Thanks I'll try it and let you know how it works.
Old 09-24-08, 07:26 PM
salimshah
salimshah's Avatar
Received 1,046 Likes on 944 Posts
Do you have a gauge connected that tells you that the vacuum is being lost?
Finding the leak is hard as the vacuum lines run to various places. Old technique is to spray the connectors with carb-cleaner. The extra gas is sucked in and the rpm shoots up.
just investigate to make sure you have a vacuum problem and all other sensors like the IACV are working.
Salim
bmatic01
Performance & Maintenance
12-29-15 03:37 PM
XxPainxX
01-16-12 10:22 AM
dcaldwel1
09-07-11 06:43 AM
canman44
SC- 1st Gen (1992-2000)
17
08-02-11 12:54 PM
jagalchi88
04-11-10 06:43 AM
Quick Reply: vacuum problem
