Wipers work No Fluid
I replaced the pump - same symptoms as yours except reversed - front worked, back didn't.
https://www.clublexus.com/forums/sho...d.php?t=249476
The pump is just held in place by the form fitting on the back of the reservoir. Anyway, it's pretty easy. Take wheel cowling off, disconnect lines, pull pump straight out and replace.
Drain reservoir first. I siphoned mine using the lines off the pump if I recall.
Yeah, I'd skip the CarQuest part. You may have to deal with voltage differences, adapters, etc. Just go get the Toyota part.
The pump part number is: 85330-20470
No I only removed the front part. In fact the photo in the thread shows I was able to just take out a couple of screws and pull back the cowling. It's just a few screws.
Ryan
