Wipers work No Fluid
for some reason the wiper fulid does not come out when I try to clean the windows... Checked all fuses.. what and where is the relay. Any Ideas?
1 Post
ok i know this is gonna sound really retarded but hear me out
i used to take my car to jiffy lube all the time and they always would fill up the windshield washer fluid for me so i just never checked it, well i guess they just forgot to do it a bunch of times and im guessing it went dry
anyway so i bought some fluid and filled it up and ran it.....and ran it.....and ran it....oh! and ran it and nothing was coming out, opened up the thing and it looked like it was all gone so i filled it up again and repeated the process but nothing ever came out, so awhile later i started messin around with it again to see if maybe i had a leak or maybe the pump was bad or something and eventually it started coming through, the only thing i can guess is that it was just bone freaking dry and it took awhile to actually get it to through all the tubes
but now it works with no issues so i dunno, hope this was helpful, if not i just made myself look like dumbass for nothing lol
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Did the fluid in both the front and rear stop about the same time? If one or the other works, it is likely not the pump. If both front and rear stopped working about the same time, it could be the pump. If you search, you will find the alternative Toyota part number (to save money) for the pump, the way to access the pump (to see if you get fluid flow at that point), etc.
Maybe it's premature to be mentioning the replacement of the pump, until you verify that it is getting electrical power and is still not working.
I still dont understand how the front and rear are operated by one pump? Is their some kind of diversion valve thats in their some where?I put compressed air through my rear line (30psi) and it blew through my res.and came out the front washers,so I know its not blocked.Maybe my combination switch is bad?
It sounds to me like to still need to access the pump and verify whether or not it is getting electrical power and whether or not it is pumping. From what I've read on this forum in the past, a pump failure is getting to sound likely in your case.
It happened to me before. One pump with one inlet and two outlets. When motor turns one direction, fuild comes out the front. When the motor turns the other direction, fluid comes out the back. The pump on mine can only turn one direction (the front) probably due to the corrosion caused by the salt used arround here. The replacement is very easy, plug and play. There is DIY here a while ago.
Super Moderator
You'll find the reservoir and attached pumps behind the front bumper on the passenger side. This is a thread with some of the pictures of the reservoir, https://www.clublexus.com/forums/sho...d.php?t=311719 (which I removed so I could give the tranny cooler some better ventilation).
I should probably take my pump out,and try to see whats going on.Thats what I should do,will I? Probably not...........
sometimes I just dont feel like tearing things apart.Is this relatively easy to remove Lex?
Every time I have had that problem over the years (a lot of years and many clogs) It has always been the tiny holes where the fluid comes out. (They sometimes have 1 hole, sometimes 2 per nozzle) They seem to clog fairly easy from the washer fluid drying in there. What I have always used is a welding torch tip cleaner set. They go down to a very small size, are very hard and I have plenty of them.
That and some compressed air. A pin is usually too small to go all the way to the back and will probably only pack it further back in without clearing it. A small possibility that compressed air alone will clear the nozzle if it isn't too hardened. Good Luck!
Super Moderator
Yeah, it's relatively simple. Once you get that plastic wheel well cover off, it is pretty simple to take out and then put back in, I don't remember too many complex connections that the reservoir needed and I believe it was only attached to the vehicle by two bolts.
You need to get to one end of the pipe/hose.
If you want an easy way you can cut and later splice.
Salim.
Salim.
https://www.clublexus.com/forums/sho...d.php?t=249476
The pump is just held in place by the form fitting on the back of the reservoir. Anyway, it's pretty easy. Take wheel cowling off, disconnect lines, pull pump straight out and replace.
Drain reservoir first. I siphoned mine using the lines off the pump if I recall.
