Atf Filter Change W/o Small Black O Ring
Hi,
I changed transmisson fluid for tranny pan, tc and the front differential and the new filter. But i didnot find my old o ring (black plastic ring) for the atf filter. So i install without it. Any problem for this tranny ? Now i feel that my tranny is not smooth. It has 98k mileages. suggestions welcome.
When I was changing my filter it did not come out with the filter but was stuck in the inlet where the filter meets the transmission. I had to pull out manually. The same thing might have happened to yours. If so I wouldn't worry about it as when you were putting the new filter back in it should have inserted itself back in........but the only way to find out for sure is to open it back up.
Super Moderator
Hi,
LexChamp
07-05-07 08:14 AM
