Heater blowing cold air
Old 03-02-20, 07:37 AM
  #121
goomz
goomz's Avatar
Originally Posted by UncleL
I realize I'm replying to a thread from 5 yrs ago but I wanted to ask if this problem was causing overheating? I just noticed the "hampster wheel" noise last week and then I overheated yesterday. I turned my climate control off and on and then turned on heat to HI and the engine temp went down enough to get home (5 min.) I'm just wondering if you all on this thread were more interested in heat and AC for cabin temp or engine temp? Thanks
Your issue sounds like a bad thermostat or low coolant, this thread is based in hvac heater temps
Old 03-02-20, 07:42 AM
  #122
UncleL
UncleL's Avatar
Yes, I checked an topped off coolant but neither of these would cause the hamster in the dash noise that has accompanied the overheat issue??
Old 03-02-20, 08:26 AM
  #123
goomz
goomz's Avatar
oh I thought you meant hamster wheel like as in maybe a water pump. That sounds like it may be a bad blend door motor maybe? I had to replace the two of mine on under the glove box, and the relay that's behind the heater core tube. The only actuator I did not change was the recirc one that's above the glove box area
Old 03-02-20, 08:30 AM
  #124
UncleL
UncleL's Avatar
OK, this is what I'm trying to narrow down. Would a bad blend door motor cause overheating? The noise sounds exactly like a vent or a damper opening or closing. Thanks
Old 03-02-20, 08:36 AM
  #125
goomz
goomz's Avatar
I'm no mechanic, but I doubt it
Old 03-02-20, 05:27 PM
  #126
maxSteel
maxSteel's Avatar
Running the heat at full blast can provide some small engine cooling benefit. I'd done this in the past to help bleed off some heat when I had an overheating engine while stuck in traffic in the summer. Not a pleasant experience.
But the engine overheat is not caused by the cabin heater.
RXUUP
11-14-21 02:22 PM
bigcat88
12-19-16 12:24 PM
mfalcon
10-29-16 06:04 PM
qwijibo419
08-26-10 11:50 PM
krypttic
RX - 3rd Gen (2010-2015)
04-21-10 03:24 PM
Quick Reply: Heater blowing cold air
