Front Suspension Noise
TSB SU002, 99 Dec 99, apparently addresses the issue of 'front suspension noise.' Can someone please tell me what that TSB says?
JAB- I don't know what that refers to but I can tell you for a fact, the most common front suspension noise is caused by wear and degradation of the rubber in the upper strut mount plate. The R side is the most common, but if you have a '99 i would replace both of them. When they get some miles on them, going over a bump or a pothole will wake the dead. Sure not going to go to sleep driving on a rough road. It is metal against metal.
Thanks. (Please note that I corrected a typo in my original post; I meant to say TSB, Technical Service Bulletin.)
PS - on the parts diagram, which particular part are you describing? Part 8, 9, 11, 12, 13 or 14? TIA. See http://www.mylexparts.com/partlocato...layCatalogid=0
Super Moderator
Part 13 in the diagram, lower support (rubber), I like to use plastic hosing instead. I replaced my lower rubber supports a few times in Mexico and finally went to the plastic hosing permanently when I did my shocks. 11 would be the possibility (though I had no such issues when I checked mine and replaced my shocks in January).
kyk007
13
04-04-15 09:36 PM
