P0440 Engine Code
P0440 Engine Code
2002 RX300 141,000 miles
Had the code read at Autozone.
Replaced the gas cap, code came back.
Any other likely causes besides a disconnected hose. Unless a hose is cracked or came off by itself I don't think its a hose. I do need to do a thorough check though.
Thanks for any tips.
Alex
Alex
Alex
Alex
It may also be your charcoal canister is bad,(by the gas tank underneath the vehicle)
Super Moderator
P0440
Vapor Pressure Sensor
Fuel tank cap incorrectly installed
Fuel tank cap cracked or damaged
Vacuum hose, cracked, hole, blocked damaged or disconnected
Hose or tube cracked, hole, damaged or loose seal
Fuel tank cracked, hole or damaged
Charcoal canister, cracked, hole or damaged.
Patrickleo
06-27-16 09:42 AM
