Lexus rx300 2001 wont start.. Please Help!
Old 11-17-08 | 09:06 PM
elacesar's Avatar
elacesar
Default Lexus rx300 2001 wont start.. Please Help!
Hello all my lexus all of a sudden does not start and i can only see
the attention light on the right of the check engine light blinking.. It is a
shape of a car with what seems like flashing lights on the rear. Please someone give me a little help with this...Thanks for any help..
Old 11-17-08 | 09:20 PM
liquidsilver's Avatar
liquidsilver
You need to be more detailed about the problem. Does it crank over? Does it start and stall? What does it do when you turn the key? Also the light on your dash doesn't seem like its Check Engine Light....it seems more like burnt tail light warning or Vehicle skid control failure warning.
Old 11-18-08 | 05:24 AM
elacesar's Avatar
elacesar
Default Lexus rx300 2001 wont start please help!
Thanks for replying.. Okay i could get the car to start but it wont idle. If i hold the gas pedal it will run but when i let go of the pedal it turns off completely. Any help please!
Old 11-18-08 | 06:39 AM
UNOHOO's Avatar
UNOHOO
I had the same issue with mine a few years ago. My friend said it was either the MAF sensor or fuel pump going bad, i replaced the MAF sensor and TADA!! it worked. May not be your issue but that was my experience. One thing you could try before going out and buy and new MAF sensor is going to advance auto parts or a similar place and buying some MAF sensor cleaner and try cleaning it first to see if that works. If not the sensor may be just completely shot. Hope this helps
Old 11-18-08 | 08:01 AM
lexus114's Avatar
lexus114
sounds like your i.a.c valve (idle air control)
https://www.clublexus.com/forums/sho...d.php?t=358579 this link is on a sticky,check it out.
Old 11-18-08 | 08:44 AM
elacesar's Avatar
elacesar
Default lexus rx300 2001 wont start..
Thanks for the great help guys it took me 30 minutes this morning and shes working like a charm!! Great Site..
Old 11-18-08 | 08:45 AM
UNOHOO's Avatar
UNOHOO
thats true i didnt even think about that, derrrr lol
Old 11-18-08 | 09:59 AM
lexus114's Avatar
lexus114
happens to me all the time.
Old 11-18-08 | 10:04 AM
lexus114's Avatar
lexus114
no problem man!! that`s what were here for.
Old 11-18-08 | 10:13 AM
elacesar's Avatar
elacesar
Thanks again
Old 11-18-08 | 10:32 AM
liquidsilver
I would say start with cleaning the throttle body first. I had sam symptoms as u described on my 02 highlander before and cleaning tb worked. and go with maf sensor
Old 11-18-08 | 11:09 AM
UNOHOO's Avatar
UNOHOO
so it was the IACV?
Old 11-18-08 | 02:56 PM
elacesar's Avatar
elacesar
Yes it definitely was.. and thanks for the help
Old 11-18-08 | 09:33 PM
trhs75's Avatar
trhs75
I'll have to remember that one in case it happens to me. All of you are always so knowledgeable and helpful!
Mike234588
22
05-18-16 05:20 PM
340massive
04-20-15 06:30 PM
mno221
06-27-12 07:29 AM
jdipaolo1
04-28-11 10:03 PM
cbc's lex
SC- 1st Gen (1992-2000)
03-02-09 12:27 PM
