Help! rpm needle revs when at a complete stop
Hello all,
I was driving my mom's '99 RX300 the other day and noticed a couple of things:
1. When at a complete stop with a foot on the brake, sometimes the rpm
needle will rev up to 2 and then return to the normal position and then
just keeps fluctuating back and forth. What could be wrong?
2. The car shakes when braking - I'm not sure when the brakes were last
serviced. Any ideas?
Appreciate the help in advance!
Ben
Ben
Hello all,
Ben
Ben
1. Is likely an IACV issue, see here how to rectify it https://www.clublexus.com/forums/sho...d.php?t=358579
2. Those are likely warped rotors. You can either get them replaced or machined/turned (a.k.a. smoothed down).
Ron
the braking issue probably is your rotors, i have the same issue in mine and i believ eit was due to getting a tire rotation at jiffy lube and them tightening the lugs on too tight and warping the rotors
A bit of variation is normal as the engine rpm is regulated based on load. When you mention "2" I assume it is not 2000 and I doubt you can register 2 or 20 so it would be 200 rpm.
A/C compressor kicking in and out.
Electrical load changing, such as brakes lights turning on/off.
Once you discount for these, IACV would be the next suspect and then vacuum. Also have the OBDII dumped to see if there is a pending fault that might help you diagnose it.
Now a days, due to emission concerns, no one [including dealer] messes with idle.
Salim
Salim
natsibley
RX - 1st Gen (1999-2003)
24
05-26-16 05:33 PM
