rx300 trans fluid capacity?
Hi everyone, i'm Nick i just bought 2001 lexus rx300 AWD, i love this car,i've changed trans fluid,filter,and pan gasket, the thing is trans capacity 4.1qts but i've filled 4.7 qts, and when i check on the normal temp its beetween cold and hot in the middle,is it normal? but when i check in the morning when the car is cold its way above the Hot. what i should do?
Thanks
Nick
Thanks
Nick
How are you checking?
Should be in Park, engine running, flat surface, after 15-20minutes of actual driving.
Salim
Salim
Thats what i did, i drove about 20 miles, put i park, took the trans dipstick out and its between cold and hot, does it meen is not enough? here is a pic wet dipstick marks, go dow to find a pic.http://http://rx300how2.home.comcast...id_change1.htm
For FWD:
If you drain from the transmission AND the front differential, you need 4Qts.
Salim
Salim
I think once the car is in park, it shouldn't matter if the engine is running or not since the drive shaft shouldn't be engaged and so the torque convertor should be rotating anyway.
As for level, don't overfill either, it's almost as bad as underfilling.
2001, 300, awd, capacity, checking, chkin, differential, fluid, lexus, rx, rx300, rx300 awd trans, specs, trans, transmission
