Front Side Marker Lamp Socket
Does anybody know where I can find the socket for the front side marker lamp (left or right, same thing) with the pigtail or have a part number for them with pigtail? I went to the dealership and I was told I can't get the pigtail unless I order a new wiring harness.
My current one got rusted out really bad because of the washer fluid reservoir being next to it dripped into it. It basically broke apart.
Thanks again, i'll also post in classifieds.
Not sure what you're calling a "pig-tail" or exactly what you want, but my front driver's side wore out also to the point where the metal inside actually was gone (probably fell out at some point) and there was oil or some residue in there.
Anyway, I called Irontoad.com and got part 90075-60001 (Socket Plug) whic is the part that holds the bulb and screws into the marker. The other end is the side the wire plugs into this part. It was $8 I believe each.
