Heat unavailable
2001 RX 300, 115K
I can't get the heat to come on or the air temperature to change. It's always cold, even when I turn the **** all the way to "max heat". is it a thermostat problem?
Thanks.
Thanks.
do a search on "air servo" ... these control various dampers to direct air.
Salim.
Salim.
Do air servos control the temperature? I don't have a problem with air direction, that works fine. It's just that I can't get the air temperature to change. It's always cold.
Thanks.
Thanks.
Salim
Salim,
I'm starting to think that you might be right. I have been hearing ticking in the dashboard for the last 6 months or so, and I read on the forum that it had something to do with the servo.
Thanks.
Thanks.
It's the air mix servo that lets in the heated air. You can manually open the gate to get hot air until you get a chance to repair it. Look here:
https://www.clublexus.com/forums/rx3...-cold-air.html
lyoooha
01-07-15 09:51 PM
