My rx300 car will not start.
Old 02-22-09, 02:00 AM
guest
guest's Avatar
Default My rx300 car will not start.
I just parked my car and now it will not start. It trys to turn over, but will not. Can anyone help me?
Old 02-22-09, 07:08 AM
thomas1
thomas1's Avatar
When you say tries to turn over, does the starter actually grind over and the engine wont start...?
Old 02-22-09, 08:28 AM
salimshah
salimshah's Avatar
Received 1,086 Likes on 977 Posts
Is the starter spinning the engine as fast as it normally does, or the spin is slow? [problem areas, battery, terminals, starter]
Does your clock show reset to 1am? [failing battery]
Salim
Old 02-23-09, 11:02 AM
lexus114
lexus114's Avatar
Salim
Well,ya can`t help em if he doesn`t get back to ya.....
Old 02-23-09, 07:19 PM
salimshah
salimshah's Avatar
I would like to think, that the problem is solved.
The poster is no longer looking for further assistance.
Salim
Old 02-24-09, 06:33 AM
lexus114
lexus114's Avatar
Salim
Got it.....
Old 03-03-09, 10:54 PM
guest
guest's Avatar
I'm sorry everyone. I just got back from Cancun. The car trys to turn over, but will not start. The clock in the vehicle still holds the correct time.
guest
guest's Avatar
The starter does not grind.
Old 03-04-09, 06:52 AM
lexus114
lexus114's Avatar
that could be a couple of different things.iac valve,low or no fuel pressure,crank shaft position sensor,coolant sensor (doubt its that one though) was your cell on before you parked it? (check engine light)
Old 03-04-09, 07:03 AM
thomas1
thomas1's Avatar
If the starter doesnt grind, than maybe something in the starter circuitry. Do you hear a click when you try to start the car?
Old 03-04-09, 07:31 AM
mikey00
mikey00's Avatar
"Car trys to turn over" usually points to battery/starter type problem. The fact that your clock is not resetting eliminates the battery. Or do you really mean car is turning over (meaning the battery/starter is cranking the engine, the engine is spinning or turning over but it just won't start). If this is the case try working the gas pedal to get it to start. If it starts using this method it is most likely the IACV (idle air control valve). If you just do a search on it on this forum there is a procedure on how to clean it.
If it truly is not turning over, I would suspect the starter. There is also a procedure on the forum on repairing the starter solenoid contacts.
Both IACV and starter solenoid contacts are common problems in the early RX.
Old 03-04-09, 07:51 AM
UNOHOO
UNOHOO's Avatar
also, what year is it? how many miles have you logged on it? how was it acting prior to you parking it?
i know one time i had a similar issue except mine would start and just not stay on, turns out it was my maf sensor but if yours doesnt start at all that may not help.
Kalogerus
Performance & Maintenance
14
02-04-12 02:05 PM
jbl-1985
11-25-09 04:20 PM
ynvme
06-26-06 08:57 PM
Benjamin T
Maintenance
11-23-05 07:31 AM
Quick Reply: My rx300 car will not start.
