Removing Steering Column Cover
Thanks so much..
I saw the one underneath, but missed the 2 behind the wheel.
This is where a noise is coming from when the wheel is turned. Sounds like 2 plastic pieces rubbing together.
Thanks Again
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
Are you sure it's from under there, and not in the clockspring behind the steering wheel? You'll be able to see the sides of the clockspring box, but to gain access to the front of it, you'll need to remove the wheel =/
the noise has been there for years and I've learned to ignore
it because it only makes this noise in the winter when the
temps are below 40.
I hope the OP figures out how to get rid of this noise. If so,
please post on which part is the culprit.
told me it's the clockspring which had to be replaced)
One common cause is one of the two shell pieces [start of this thread].
Before you open anything try squeezing the pieces and note if the noise changes as you turn the wheel.
Salim
Salim
PERRYinLA
SC- 1st Gen (1992-2000)
01-09-03 10:18 PM
