Annoying sounds from front of RX
I am having some sounds from the front end of our RX, every time we hit a small bump, it sounds like someone is dribbling a basketball under the hood. We have been told it is the strut caps or mounts.
I was told that beside being annoying, there is no safety issues. Does anyone know if this is true?
Is this common on the RX's? Is this something I can fix myself? I have a mechanic friend that says he will do it for $300, that includes parts and labor.
First figure out what is the real problem.
Noise can be from too many places.
Source of my annoying sound was near the radiator and close to the horn [the one in the way of the oil filter]. It took me weeks to figure out that the vertical reinforcement member underneath the horn was loose. I had to work blind but once the bolt got tightened, the noise was gone. My cost $0.00
Salim
Salim
Super Moderator
I'd have someone observe the vehicle as you drive down a street and see if you can identify the sound that way. Helped a lot when I lived south of the border and had strange sounds.
You probably won't be able to replace them yourself because you need a spring compressor. No, it shouldn't be unsafe IF it is a strut mount, but from what you've described, it may be something else.
