New Dashboard Alert
Ok, I noticed today that light a in the lower right of my dash board came on today. It appears to be the tale lights (shape of the car with what looks like lights coming off the rear of the car). I forgot my owners manual when I left the car today other wise I would look it up. I don't feel like walking the 5 blocks back to the parking garage to get it so I thought I would ask in here while I am at work. Does anyone know what this is?
It was on once before, but when I turned the car off and turned it on again the light went off.
Your tail-lights are faulty. Either your brake lights, tail lights, high mount center light, or reverse light are blown. Check everything back there and something should be out. Make sure to check the center brake light.
I was too curious to wait. The problem is the high mount center light is out. the other problem is I cant figure out how to get to the light to change it. It seems it is built into the car. Is there a DIY on this?
Was this the original bulb? I've found that for some reason, OEM bulbs will always last much longer than replacement bulbs. OEM went until like 60K and then after that, no matter if cheap Walmart bulbs or 2x-life, or Pepboys, all the same, blows out after about one year.
Anyway, once you replace the light, the indicator will go off.
If the trim has NEVER been removed, it will be tight. If it's been done before, it might even fall right off. I've done them so many times, the cips are going loose, but atleast the trim is not creeking while I drive.
When I say pull starting from middle, I don't mean to start at middle and continue pull from middle and rip it out in one pull. I mean to start at middle, when clips release, then move out a little more and pull again, until you get to ends.
Good luck... may the Force be with you.
IStoSC
02-04-10 10:19 AM
