changing out my rotors this weekend, any suggestions?
Super Moderator
I saw these (not mine),
http://www.youtube.com/watch?v=M1LTjoQjLKY
http://www.youtube.com/watch?v=SEf1wsf-xS8
If it is not rusted together, the front rotors would practically fall off when you lift the caliper. If rusted, you may like to use rubber mallet or penetrating oil like liquid wrench and let it soak (overnight if needed) .. patience.
1. Have a string or coat hanger to suspend the calipers.
2. If your rotors are aftermarket or NON OEM. make sure the outer diameter match and the inner diameter are good.
Salim
Salim
1 Post
i picked up some by centric, seem to be pretty decent and they have a coating on all non friction sections to prevent rust, dont really have a whole lot of loot to drop into it right now as im working on buying a house before the end of the month
1 Post
1 Post
Salim
Salim
You should bleed the brakes, but if you suspend the caliper and dont mess with the fluid it will work fine. if you are adding new pads, push the caliper pistons back with a c clamp and piece of wood. Install new rotor, mount caliper and new pads, and push the brake peddle a few times. Just dont break the hydralic line open, that can induce air into the system.
You may want to pick up a couple of 8mm x 1.0 pitch bolts ahead of time. There are 2 holes threaded into the rotors to break it free from hub. Works better than beating on it or soaking.
