Low Hum. Help!
Low Hum. Help!
'02 65K miles.
Extremely low frequency nearly subsonic hum. Imagine a 40' giant humming a single low note. I have very sensitive ears and it's really bugging me. Only audible at idle with tranny in gear. When I put it in neutral, sound is gone.
Just had transmission flushed (2nd time in a year). Tranny works perfectly otherwise.
Could this be just a resonant sound from something else?
Any ideas will be welcome.
thanks in advance.
thanks in advance.
i wonder if when in gear,maybe its something in the exhaust system doing it some how.of course with these trannies,i would believe anything.
I started noticing that on mine too (2001 with 65K). It sounds like a truck is idling behind you. I can't find any easy things like an exhaust leak. I'm thinking it is just a resonate sound from the exhaust system. The damper weight thing on my exhaust fell off a while back, maybe that sound is what it is supposed to suppress? Do you have the original exhaust system with the weight still in place?
This is the weight: https://www.clublexus.com/forums/rx-...t-is-this.html
Thanks for the info. You guys are great. I'll took a look under the car, and noticed the weight you discuss. It looks brand new. I hit things, I pushed things, nothing seems amiss. I couldn't get the sound to happen.
I also noticed that it only happens in 'D', no other gear, and not every single time I'm idling either, maybe 80% of the time. A truck is idling behind you- good description.
Any other ideas?
Any other ideas?
Super Moderator
I'd have someone sit in the car with the vehicle in D and their foot on the brake and see if you can isolate the hum.
There could be a tiny exhaust leak somewhere that could be affecting the tone somewhat. I know when I have had such leaks before (no matter where they were on the piping) that it would change the tone slightly after the leaks were sealed up.
Usually the resonator (the fat muffler underneath the vehicle) is where the sound will turn into a hum and it won't be audible from the muffler.
'02 65K miles.
thanks in advance.
thanks in advance.
Well, you'll never guess what it was. the idle was too low. they cleaned the fuel injection and got rid of the carbon buildup. Cleaned combustion chamber, oxygen sensor and catalytic converter.
Ahheck01
Performance
31
07-06-15 03:16 AM
