Ivory with Brown-Gray interior; scratch coverup
I have Ivory leather with brown-gray glove compartment, center console.
I have been carrying pipes and garden equipment and have superficial scratches on the gray-brown plastic. They are not deep gouges, but none the less the edges of garden stuff has scratched it up.
Any tried and tested solution?
Salim
Salim
wet-sanding with ~800 grit sandpaper, brushing with steel wool, polishing with 3m scratch remover to get the shine to match the rest of the area.
Works great And as long as you go with the grain of the dash, you will never know a scratch was there.
I never considered using the 3m scratch remover on vinyl/leatherette. I will give it a try in a hidden corner.
The surface scratches are no worse than steel wool would leave behind (although the steel wool will leave a patch while the scratches I have are lines)
Thanks
Salim
Thanks
Salim
Thanks,
Yosh
SParker1tx
Automotive Care & Detailing
05-30-07 04:23 PM
