Did someone snap off the bolt heads Brakes
I have a 1999 rx300. Changes front driverside no issue. Went to rear and the top of the caliper where I thought would be a bolt head (Front has top and bottom bolts). There is no bolt head. I climbed under car and looked at opposit side. It looks as if on passenger side the top of the caliper (Where a bolt should be?) has no head either. We never di thid before and I was looking for pictures of rear caliper to see. But did someone snap off the bolt heads on the tops? The bottom caliper bolt is on each side.
I am going to do front passenger side first while people anser.
HELP!!!! Pictures!!!
Jim Duffy
Jim Duffy
Front was piece of cake....couldn't get rotor off rear but they were not bad . Now I have to rear rotors that are brand new for the rear. But want to know how for future
There are 2 bolt holes in each rotor. These are so you can insert 2 bolts which will push off the rotor. Also make sure your e brake shoes are not adjusted tight and holding on the rear rotor.
SGLexus
07-17-23 11:39 PM
matrix
02-24-12 05:39 PM
350PsDMeuP
Suspension and Brakes
24
10-25-08 05:00 PM
