90,000 mile service - overdue
Super Moderator
There's 9 liters for the entire cooling system capacity. Each bottle is 3.785 liters. What I do is I also dump into bottles (.355 liters each) for coolant additive. My favorite now is Royal Purple Purple Ice, but that can be expensive and I've only seen it at Pep Boys. Redline's WaterWetter is also a possibility (and cheaper), but I've noticed what I like to term 'floaters' or pond scum on the top of what is in the coolant reservoir after using the WaterWetter.
Lexmex:
That is what the additive is supposed to do. Things float due to buoyancy and surface tension [you can float a metal blade laying flat on water]. The additive is to mess up with surface tension and help the fluid stick better to the block. The floating scum is an indicator that the wetter is working.
Needless to say .. I am not a fan of additives. Not that they dont work .. the return on investment is poor for ordinary use.
Salim
Salim
Super Moderator
Lexmex:
Salim
Salim
I did a search for this and came across this when I was still in Mexico, http://pages.prodigy.net/jforgione/MB_WW.html
Personally, I'd rather not have any of this stuff floating up there in the coolant for any reason. Plus, if someone is not aware that there is an issue with this oily film, they may mistake it for a potential problem.
I think these additives depend a lot on climate and/or use. Here in South Florida, I would expect a benefit as I did back in Mexico, but other areas in most of the U.S. that see not too much seasonal change, probably not.
Thank you. Will all the coolant come out when i do the water pump?
Ninja edit: .... and do I mix it with distilled water, or it goes straight?
Super Moderator
Go with distilled water.
Bob- Actually the red is called "long life" and the pink is called "extra-long life". I personally like the red better (even though it is called "long" rather than "extra-long"), so when I changed my wife's '02 Camry at about 3 yrs. I replaced with the red rather than the pink.
Also, if you get the red, the easiest way to get a 50-50 mix (ideal)is to get a couple of gallons of distilled water at Wally-World (Wal-Mart) for about 75 cents a gallon and use one gallon of coolant and one gallon of water. Then with the empty gallon coolant jug fill half with coolant and half with water. I pre-mix it and store it that way, ready for use.
mick_foley
19
10-06-08 06:10 AM
2005, 300, 90000, california, es300, is300, lexus, lx470, maintenance, mile, miles, rx300, rx330, service, servicelexus
