The 3rd brake lamp
Old 04-27-09, 06:24 PM
deflex
deflex's Avatar
Default The 3rd brake lamp
The 3rd brake lamp bulb was replaced. The light did not come on, i checked fuse it appeared to be fine. I tested the wires that leads to the socket doe's not have any juice.What should i do
Old 04-27-09, 07:18 PM
salimshah
salimshah's Avatar
Received 1,050 Likes on 948 Posts
You got to trace the wires the down. Right behind the socket, there should be a connector. You may have to get your hands on the circuit diagram to help trace on paper.
Voltmeter can be handy to trace a break, but for corroded joints, having a bulb which draws current is better. Corroded joint in Lexus is very unlikely.
Salim
Old 04-28-09, 05:26 PM
AlexusAnja
AlexusAnja's Avatar
Default 921 bulb
Dumb question, but did you put the right bulb for replacement? The RX300 center bulb is a small 921 bulb. There are plenty of bulbs that "look" the same, but they are different numbered because of electrical draw, base fitment, etc. Maybe you have the wrong bulb and it's just not coming on?
If it was working before, and you're replacing because the blown light indicator came on, then doubt a bad line "all of the sudden" came out. Unless of course your line went bad instead of the bulb.
Old 05-11-09, 06:50 AM
nar8ta
nar8ta's Avatar
Anyone know where we can get our hands on the wire diagram of this vechicle. This problem is bugging us out. The mechanic used a test light and still no juice. If anyone has a link to a wire diagram with color code it will be greatly appreciated.
Old 05-14-09, 01:00 AM
nar8ta
nar8ta's Avatar
anyone????
Old 05-14-09, 08:01 AM
thomas1
thomas1's Avatar
There are some in Haynes manuals. The third brake light goes to the ligt failure sensor (where that is i dont know) it is a green/yellow wire. there should be a green/red wire also which is the rear brake lights wire. From the light failure sensor the green/white wire goes tothe stop light switch.
EkimAtled
12-04-18 11:11 AM
EENCIZO
02-21-11 08:46 AM
gerbjones
08-31-05 12:12 AM
Quick Reply: The 3rd brake lamp
