Hello from Austria
Old 05-13-09, 11:57 AM
  #61
gazi001
gazi001's Avatar
Let us know if it fixed.
Old 05-15-09, 04:24 AM
  #62
Lexmex
Super Moderator
Lexmex's Avatar
I think you may have already done this one (can't remember), https://www.clublexus.com/forums/rx3...-write-up.html
However, cleaning this can reduce some idle issues that can cause a P0171.
Are those sensor readings you got changing over time on the banks?
And what is the high reading/low readings that you get?
Old 05-15-09, 06:51 AM
  #63
Boergy
Boergy's Avatar
Hello!
Thanks for the link!
i cleaned the valve with brake-cleaner. it was not ok, but not the failure but the idle speed is ok
Today, i changed the Transfer oil, is very easy to change. Is this oil old or newer?
I checked the exhaust system of holes, no holes, only by the new gasket was a little bit black, i cleaned with sand paper and gives exhaust repair mass. And by the springs washers for more pressure.
i would be change the oxygen sensors from bank 1 and bank 2 to change, but the sensor was tight after 1 turn any solution for this problem?
i orderd a new maf-sensor to test. its 176tkm old, looks ok....i test
the failure comes for a short time (5sec) the engine bucking very little and runs after this normal, not more consumption, normal power. ist day to day better.
yesterday comes my new summer tires, its Falken Ziex 912
greets
Tom
Old 05-16-09, 10:58 AM
  #64
Lexmex
Super Moderator
Lexmex's Avatar
Tom,
If you are only getting P0171 and not other errors, then the exhaust sensors would not be a problem. I wouldn't worry on changing them. I get P0171 codes every so often, but I used to get them more often when I was in Mexico and did a lot more experimentation with intake and exhaust modifications. There may be something there that is too small to detect.
Did you also change the oil in the rear differential?
Old 05-16-09, 01:22 PM
  #65
Boergy
Boergy's Avatar
Hy!
Only the P0171 failure. one time was P0174.
Yes, i changed the rear diff oil. this lokked better as the transfer oil.
Today, i changed the springs from Eibach to Original. The suspension is sometimes to hard. I test with the Original springs and the Kayaba Ultra SR
To change, i needed 2,5h with wheels change ist very easy on the RX to work.
Old 05-25-09, 09:05 AM
  #66
gazi001
gazi001's Avatar
Thanks Thomas. Last Saturday i received my Delta exhaust from Germany but there is no manual or instructions how to install with my RX 300 AWD. I contacted with the seller for the manual but he told me that there was no manual in the original box. So i need the manual but don't know where to get it? Do you have your manual? Is it possible to give me a copy if so? Thanks.
Old 05-26-09, 08:21 AM
  #67
Boergy
Boergy's Avatar
Hy!
I look today for the manual, i have oin the outside many of papers in a letter. I installed the system without manual
Is very easy.
demount the old exhaust (last sektion)
demount the left (driver side) the towing lug ans mount the holder
install the new hook on the frame for the new left side exhaust (its only one hole)
install the rubber bearings on the new hooks
mount the right side exhaust with the y-pipe and make a marker on the original exhaust pipe for cut this.
Cut the pipe (the original pipe goes in the new pipe and fixed with a clamp)
install the right side exhaust, thy y-pipe on the original pipe
install the left side exhaust with the pipe, is not easy to install all pipes in one step.
adjust the exhausts correct and fixed the clamps.
i hope you have not the gas tank cleaning unit under the chassis on the driver side!
greets
Tom
Old 05-27-09, 12:51 AM
  #68
gazi001
gazi001's Avatar
Thanks Tom. I will try to install the exhaust in saturday.
Old 05-27-09, 08:02 AM
  #69
Boergy
Boergy's Avatar
Hy Gazi!
i looked in the cover, only the legal certifications and a small instruction manual, without picture and very simple, not specific for the RX300
Today, i become my maf-sensor!!
a short look in the sensor, i see 1 wire and 1 resistor is this normal or a upgrade maf-sensor? my original Sensor have 2 wires.
http://cgi.ebay.com/ebaymotors/02-06...Q5fAccessories
i have bought this one? is this correct?
Thanks for help
greets
Tom
Old 05-27-09, 10:39 AM
  #70
gazi001
gazi001's Avatar
Hi Tom,
I never try after market sensor. It looks ok but never try c&c parts. Hope it will works for you. Following link for OEM Air Mass Sensor:
http://www.mylexparts.com
Old 05-27-09, 10:58 AM
  #71
Boergy
Boergy's Avatar
Hy!
Ok, i test this part.
Thanks for the link, i order the original part, if the c&c product fail.
Old 05-27-09, 12:24 PM
  #72
Boergy
Boergy's Avatar
Hello!
i have installend, after 10km the first failure, P1133 (insufiance switching O2Sensor bank1) and after new start and reset P0100 (MAF Sensor flow failure).
i change back and test again. i think, its from the new maf sensor the current consumption is also high, higher as with the original sensor.
*edit*
i changed the maf sensor to my old one, normal consumption, no failure.
Old 05-27-09, 04:27 PM
  #73
Francis
Francis's Avatar
Welcome Tom. May be I should call you Mr. Mods bug. It is good to see somebody put that much love to the RX. Hope you will solve the OBD code problem soon. Cheer!
Old 05-27-09, 10:52 PM
  #74
gazi001
gazi001's Avatar
try to use oem mass sensor.
Old 05-28-09, 02:02 AM
  #75
gazi001
gazi001's Avatar
You mentioned about gas tank cleaning unit under the chasis on the driver side! I have a black box under the chasis on the driver side. Is it gone a be difficult to install the exhaust in the left side? Here is the pic. Is this gas tank cleaning unit!
Quick Reply: Hello from Austria
