Hello from Austria
#76
Hy!
We have in Europe this box not!
Today, i have become the original Toyota MAF Sensor and th e new Original Cas Cap.
I installed boths, but the failure comes back. bevor i startet the test round, i resetet the ECU.
mh...its only when i drive slow with low throttle position. maybe a injector have problems? (bucking when the problem comes)? Or the A/F Sensor gives wrong values? i will test tomorrow to change the A/ Sensors from Bank 1 and 2, but the sensor an bank 2 is fixed![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
I teste for 15minutes, the gas tank makes zisch, if i open the gas cap
#77
Super Moderator
Hy!
I teste for 15minutes, the gas tank makes zisch, if i open the gas cap![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
#78
HY!
i feel, the engine runs not normal, as one zylinder not runs, after kickdown runs the engine normal.
Today, i checkt again the hoses. On the valve the hoses was very easy to demount. i changed the hoses, checked all electric valves and hoses. there all ok
But i found a failure from me
the clamp after the maf to fix the big hose to the airfilterbox was not fixed! maybe this the failure with the new sensor? i will test tomorrow.
Here some pictures from today:
The original maf:
![](http://666kb.com/i/b9dopt8dae06qzcf5.jpg)
the C&C maf:
![](http://666kb.com/i/b9dpe3d9nsjfxr4bl.jpg)
old gas cap:
![](http://666kb.com/i/b9dpgcu4511dy6sgx.jpg)
new gas cap, i feel the gasket if i closed the cap and he makes "zisch"
![](http://666kb.com/i/b9dpiff408c8g43oh.jpg)
the new hoses on the valve (the 2 hoses was have 180° bow)
![](http://666kb.com/i/b9dpkx18qh3w2arhd.jpg)
Boergy @ work
remove stone chips
![](http://666kb.com/i/b9dpnaq8bnlmq7ijl.jpg)
greets
Boergsn
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
The original maf:
the C&C maf:
old gas cap:
Boergy @ work
greets
Boergsn
#81
Hi Tom, in your picture on page #5 there was a small box like canister in the chasis. Does your muffler touch the box or do you put any insulation or heat cover to protect the canister? Thanks.
#85
Super Moderator
#86
Yes, we have tests in Austria, i have 2 pre catalysators and 1 main catalysator. I think you have also this 3 parts.
Here the diagramm, you in the USA have the charcoal Canister with 2 valves and 1 sensor.
i have normal VSV for EVAP with a chacoal Canister in small version under the airfilterbox, is the simple solution without sensor.
this is why i have not this one hose on my airfilterbox in my Euro-RX300![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
![](http://666kb.com/i/b8qbee6th090e6j94.gif)
This is the diagramm for the US-RX
here my canister in the euro-version:
![](http://666kb.com/i/b9fpfr624oi390fso.png)
and here in the US-Version:
![](http://666kb.com/i/b9fphcqe1sutdelfc.png)
greets
Boergsn
greets
Boergsn
#87
Thanks Tom for your inspiration to buy dual exhaust from Germany and installed today. I replaced the canister otherway. Here is the link:
https://www.clublexus.com/forums/rx-...led-today.html
#88
Hy!
Maybe i found the cause of my problem. Today, i checked again all hoses, cleaned again the IACV Valve and fixed all intake manifold screws. After this, i startet the engine and testet the intake manifold and the mounted parts on this with brake cleaner of holes.
No holes, all ok. But when i give short accelarate, i hear on the backside if the engine a noise, maybe a leaky exhaust manifold gasket or the manifold himself. But, i drive tomorrow 700km to a Lexus Meeting in Austria
i think, i control the manifold early in the morning in my Garage ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
greets
Boergy
greets
Boergy
#89
Super Moderator
Hy!
greets
Boergy
greets
Boergy
In the first picture, I had to weld up a leak on the exhaust manifold in the engine bay, then we also had to weld up in the second picture an exhaust leak on the piping underneath. In the third picture, this exhaust gasket in front of the main catalytic converter gave me frequent trouble and eventually I just replaced it with pipe. It is held in by 14 mm bolts. You could try tightening them.
Best thing I found was to have someone outside the vehicle take a look while you put your foot on the accelerator in Park or in Neutral and you can usually find the source of the problem. God knows I had them back in Mexico with all the exhaust modifications I did.
#90
Hello!
little upgrade. After 1500km was the consumtion 12-13L / 100km. Highways and Mountains![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I called my car dealer for the problem with my car. he is not good to motivate to repair my car
i have 12 months warranty of this car. he bought a new original MAF Sensor for me, the car runs better, but the failure comes back. He is not a lexus/toyota Dealer. it is for me too stupid to have long discussions with him band give him my car for repair.
Today, i bought on www.mylexparts.com a new oxygen sensor and a new gasket for the exhaust manifold. The sensor was fixed in the manifold. i demount the exhaust system and change correct the sensor. i hope after this action, the RX runs normal![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
greets
Tom
greets
Tom
