ABS Issue
Old 05-05-09, 10:00 AM
Androu
Androu's Avatar
Default ABS Issue
Hello everyone, I am having some weird problems with my ABS. When I am driving in completely dry conditions and come to a stop from a low speed the ABS kicks in for a longgggg duration of the stop. Any idea what this could be and how/how much it would be to fix it?
Thanks!!
Old 05-05-09, 10:28 AM
carguy07
carguy07's Avatar
Try inspecting and cleaning the ABS sensors first. It could be the toothed ring on the half shaft too. Hopefully it is just a bad or dirty sensor.
Old 05-05-09, 10:43 AM
salimshah
salimshah's Avatar
Received 1,057 Likes on 954 Posts
It could be that the ABS is working correctly , and the problem is due to traction (air-pressure, tread condition) and/or issue with the brakes [grabbing-binding].
Salim
Old 05-05-09, 02:03 PM
mikey00
mikey00's Avatar
This is a common problem on the RX and it seems to always be caused by the sensor ring which is part of the axle shaft. It is a $1000.+ repair. Check here and also related links in the post:
https://www.clublexus.com/forums/rx-...rx300-awd.html
Old 05-06-09, 06:24 AM
lexus114
lexus114's Avatar
WOW!! time for a DIY on that repair!!
ssgi4in12
06-18-19 12:12 PM
mrnetsr
Hybrid Technology
12-21-17 09:57 AM
gsCrazy
03-20-17 09:26 PM
Anthony81
05-18-16 09:36 AM
splacek007
08-13-10 07:13 PM
Quick Reply: ABS Issue
