avg MPG 14.0 city, anyone thought about adding a bigger gas tank?
At your discretion...
14 mpg. seems pretty low. Dump a few bottles of fuel injector cleaner in there at every other fuel fillup and do that for three cycles. See how that does it. You might be able to pull out another 1 mpg, maybe 2.
I have the opposite thing happen to me. I, incorrectly assumed that the plugs were replaced at 90k [did not look at the invoice] and around 140k, I got the misfire code. Called the dealer and asked if the plugs were changed at 90k and the answer I got, the plugs are scheduled to be changed at 110k miles.
I guess each dealer is different.
Salim
Salim
What is your tire side? Are they 225/75/16 (stock side) or 235/70/16(one plus side)? The 225/75/16 should give you better mpg. Clean your air filter. Also, bump up the tire pressure. Try 36 all around and see what happen.
"after they changed them out, the car revs up to 1300 RPM sounds like a Fairly loud peice of Junk car for about 5 minutes then idles at 800 RPM or so after its warmed up"
I wish mine would start up and go right to 750 rpm. I hate that fast idle/delay shift crap when its cold!!
yeah I wish they hadnt changed anything, it used to sound so nice, I had the quietest car in the family, you could sneak around anywhere with this thing and you wouldnt hear a thing.
now I have a weed eater that is probably quieter then this at startup around 1300-1400 rpm
slowly this car is becoming a problem.. well no, Im just spoiled by how a great car should work and now im being picky on this one with little things
maybe so. none of my other cheaper cars seem to do this though..no big deal though
as long as I get from point A to point B and im relatively happy with how it does it. Then all is well.
I just got 180 miles on a single gas tank..GGgggreat.....
Their has to be something causing this. What fuel/grade are you using?
actually fun surprise today
i filled up a complete tank at kroger using their 93 octane fuel..
and so far Ive been averaging 17.1 MPG..its insane..with a/c on and windows up...
i dont know what changed or happened...
good though!
so far 3/4 of a tank left and i got 86 miles so far!!
if i can get 250 out of this tank ill cheer
good though!
good though!
good though!
Wah wah wah ???
good though!
good though!
