avg MPG 14.0 city, anyone thought about adding a bigger gas tank?
#32
Funny but true
You can gamble too and maybe remove the spare tire too. The RX has a full sized spare, so that's some pretty hefty weight to lug around. You can also upgrade to a fiberglass hood to save a few pounds.
Anyway, there are little things that will result in small gains, but atleast it's better than nothing.
#34
Hey Lex,now the rear of your RX is jacked up right?? (less weight back their) I usually dont carry a full tank of gas unless Im going on a trip etc. for the exact same reason,why carry the extra weight around? 1 gallon of fuel is around 3lbs. 18x3= 54
#35
When I used to go to the track I would run around 1/4 to 1/8 a tank to keep the weight down.
#36
Funny, but it's actually true. A lot of people have just "junk" in their trunk that need to be removed. Don't keep gallons and gallons of fluids thinking the car is all of a sudden going to burst and lose all it's liquids. If the radiator bursts, having a 1/2 gallon of coolant won't do anything. Why do you have transmission fluid in there? Do you have a funnel and rachet set too? Also, ONE quart of oil.. not six.
#37
My commuter is a PT cruiser which gets about 29 to 30 mpg (freeway). When I removed all the seats with the exception of the driver the mpg went up to 32 to 33 mpg @ a speed of 70 to 75mph. Then I went a little crazy (so the wife says) and removed the hatch door last summer. A little noisey but added 1 to 2 mpg. When you commute 100+ miles 4X per week the you get a little crazy.
jskennedy
RX - 3rd Gen (2010-2015)
34
06-24-11 02:39 PM
