Can the faceplate be removed?
I dont come to the RX forums at all
so im not familiar to it, my friend has a radio that she is having removed,
but the replacement radio has a different color trimming from the current trim she has.
I want to know if its possible to take off the old trimming and place it with the replacement radio?
thanks in advanced
thanks in advanced
I just changed out the faceplate on my daughter's 99 RX. The dash-color surround, the black frame around the screen, the housing for the ***** under the screen, and the radio faceplate itself are all one piece. Snap out the U-shaped wood trim piece, and you'll see the nuts to unfasten the faceplate. (Factory radio and ***** would come out with it.)
I picked up a perfect used one from LKQ for under $100 -- maybe you could cut something out of an extra one if I understand your question correctly.
the vertical vanes are connected to the front piece. The horizontal are in the rear snap on assembly. There has to be a link between the front slider and the back assembly.
Salim
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
I just popped the pieces apart to check. The end nubs (serving as hinges) for the front vanes are locked between the tan box edges and the big dash housing -- not fastened to either one, but pivoting in between. Did I explain that OK? It's hard to put into words.
Yes, I think I get it. I found a link to the part you're referring to but it's the wrong model year (chrome strip on the fingerpiece and maybe also the wrong color):
http://cgi.ebay.com/ebaymotors/01-03...QQcmdZViewItem
I'll call the stealer and see if it's still available for my car.
PS, Sorry for hi-jacking the original thread
![No No No](https://www.clublexus.com/forums/images/smilies/nono.gif)
disco_y2k
05-21-02 11:06 AM
