driverside window wont roll up.
While pulling up on the window switch, take a fist and give the inside door panel a good couple of wacks. If the motor contacts are worn, a good jolt could bring them in contact again. If this doesn't work, you might have to pull the panel off and apply power directly to the motor itself to see if it will run. There are two wires, depending which side you apply power to, it will go up or down.
