Auto-Rx
Also tell us what problem you are trying to address?
Salim
Salim
I was looking at pics last week of engines with sludge. I noticed that there was some inside the oil fill hole area (never really check before). I purchased the car last summer with 87000 miles on her. Now she has over 130000. I have been changing the oil and filter every 3500 miles with Mobil 1 synthetic and KnN oil filter 1002. No oil consumption of any sort. Oil level before oil change is normal. Just a little concern of the sludge. Now the tranny is starting to whine on the first two gears.
But that’s another topic.
Salim
I noticed the 1st to 2nd gear whine is more pronounced on regular fuel.When I run Premium (which is most of the time) I dont notice this as much (I know that sounds wierd,but its definitely noticeably on regular).Maybe you should drop the pan,and clean the screen(if it has one yet) or change the filter if it has a filter instead of the screen.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Man, Zzorro, you put some miles on. Do the wheels ever stop turning?
I doubt that there are very many that don't have that baked on crud in the filler hole. Been quite a few pictures on the forum of the same thing. My DIL's 99RX had it and i worked with steel wool and solvent and lacquer thinner to get it off. It is so baked it almost seems part of the metal. I did get it off, and running Castrol GTX for the last 30k mi., there has been no sign of return, not a trace.
Castrol GTX,and Pennzoil conventional oils are rated highly over on bitog.How often do you change her oil code??
05RX330AWD
06-19-17 05:10 PM
