Steering Wheel Shimmy
I have always had a slight shimmy in my steering wheel. I had warped rotors because when I stepped on the brake, the pulsation got worse. I changed all rotors and pads. The shimming stop. Unitl I reached about 60mph -70mph on the highway is bad. After 70mph it starts to smooth out. And sometimes it doesn't shimmy at all, in all types of weather conditions. Any suggestions?
thanks
thanks
thanks
thanks
The first culprit with a speed related shimmy is the dynamic balancing of the front wheels.
If you want to do some work, you can swap the rear to front ... assuming the rears are balanced right the shimmy should go away.
I would take the RX to a wheel shop and have the tires balanced. This is a generic operation and you can avoid dealer.
Salim
Salim
That raises another question .... why does it need to rebalanced again and again. Unless the weights keep falling off there may problems with the tire and or the suspension.
Back to your question about off by a gram (specially on larger rim size) ... it can. Also for some tires their dynamic weight shifts as the tire warms up.
If you have lifetime balance from a tire shop, explain the situation to the tech. Have him/her ride with you to demonstrate if needed.
If you dont, then try moving the tires front to back and see if it makes a difference.
Salim
Salim
I did alignment for quite a few years and am reasonably convinced it isn't alignment, unless the car has been wrecked and not repaired properly. Also, whether it relates to your problem or not, go to Centric's site and read what they have to say about pad transfer that causes a feeling of warped rotors and what to do about it. It is valid, and it has actually worked for me, though it may not be what is in play here. Good for future reference. Good luck and let us know how you do.
Update - I checked the front end hoping to find something. Nothing. Everything in the front-end is perfect. Early this morning on my way to work, about 20 miles away 55mph+, I started out at around 60 -65, no shimmy. A couple of minuted before I get to work the shimmy started guessing that the tires warmed up by then and thed belts shifted within.
I have Dunlop Rover Tour LT, these tires weren't my choice, when I bought the car I had the dealership put on all 4 new tires so they all would be the same. Since my last update I contacted Dunlop, I am going to Blacks Tire Service, which they claim handle all their warranty claims. They are going to inspect these tires. Is there anyway they can see (visually) even if they take tghey tire off the rim, if there is an issue? Also, tire rack doesn't carry these tires. I could fid them on mavis tire website, in which there reviews state the tire is good.
I still believe the greatest chances are that your tires are defective in manufacture.
****UPDATE***** After months and months of harassing the Goodyear/Dunlop Corporation about my Dunlop Rover Touring LT tires, I finally found a tire shop to replace them under warranty. Saturday I bought my Lexus to Blacks Tire Service in Myrtle Beach. The guy behind the counter.....bought a 1999 Lexus RX300 FWD for his wife that he got rid of @ 139,000 because of tranny failure. This place did everything, inspected everything, rebalanced all the tires again, I drove it home and back, told the guy it still rides like *****, so being a fellow RX owner, he said lets get those tires off of there. I have 70% of the tire left. So he recommended (since I have to stay within the Goodyear/Dunlop tire) the Goodyear Assurance Comfortred. Any other Goodyear tires suggestions?
John- I am glad you are finally getting something done about the tires. I am betting it takes care of the problem. When we had the problem with the Yokohama's on my wife's Camry, it always bugged the daylights out of me when I drove it (not real often) because I can't stand a vibration of ANY kind. I was convinced that it was the tires, not balance because I put it up on stands (all around) and had my wife slowly run it up to about 75 MPH. You could see the cyclical imbalance (smooth and then vibrate but not any consistent pattern to it). With 20k mi on them, the tires looked like new (720 tread wear rating), but I decided if I had to throw them away, I couldn't tolerate another mile of that. The Michelin Primacy's have been like silk from minute one and also wear fantastic. I hope the GAC's are as good as the Dunlops were bad.
The Dunlops were great for off-roading and wet pavement, I did do a lot of off-roading with my RX last summer into the fall. The dunlops made a differnce with the off-roading as my friends with thier AWD vehicles had the Goodyear integrity, they didn't do so well in the sand and mud. That was before I replaced my strus, tie rod ends, ball joints and sway bar links. I beat up the RX a lot before I did all the work. Now I wouldn't be doing that so much. But the dunflops were bad even before that. And the RX compared to a Jeep Cherokee Sport, handles just as well off-road.
