Broken Wheel Lock
My old brain has finally let me down. I always IMMEDIATELY retorque lug nuts after getting new tires or alignment. Tonight I attempted to rotate the tires on my wife's RX. Been 7k since getting the new Alenzas and 4-wheel alignment check. I say check because no adjustments were necessary.
I'm not sure if I forgot to retorque or have so much faith in my alignment guy (he is meticulous) that I decided I didn't need to retorque. In either case, the rear lug nuts were frozen. I always start by removing the wheel lock first using the lock key and vehicle lug wrench. I have never had a problem since they are always torqued to 76 ft-lbs. NOT THIS TIME! On the first wheel, the wheel lock itself broke. On the second wheel, the wheel lock key broke.
I have McGard locks but don't have any paperwork on them. If I call Lexus with the VIN, do you think they can tell me which key to buy?
Also, any tips on how to remove the two broken locks? There may be enough left that I can break them with an impact wrench once I get a new key. If that doesn't work, I may have to buy a special wheel lock removal kit.
What a mess!
Edit: YIPEE! I found my McGard secret code and registration paperwork. Still have to figure out how to remove the broken locks though.
What a mess!
The best thing I ever did was to throw away the wheel locks and get 4 regular nuts from Toyota. You really don't hear of anyone stealing stock wheel/tires anymore unless you live in the wrong neighborhood. Of course I didn't get rid of the locks until I was in the same situation you are.
I ordered 2 replacement keys from McGard. First I overtightened the other lug nuts on the wheel (recommended by McGard) and then tried to remove the lock with the new key and lug wrench. First one came off. Second one snapped the key. Now I only have one key left. I used an impact wrench on the rest (recommended by McGard) and they came off. You stand a better chance of not breaking the key with an impact wrench. That is why all the tire guys like to use it to remove your locks. Of course, long term this is not a good thing. You can find some removal tips on the McGard website.
If I ever buy some exotic wheels and feel the need for locks again, I think I will always have 4 regular nuts and remove the locks whenever the car gets any kind of service and re-install them later. A hassle I don't really need.
Good Luck.
Good Luck.
Good Luck.
Good Luck.
What a mess!
What a mess!
No success. Got my Sears LUG OFF kit today. The wheel lock is so much harder than the fluted LUG OFF socket that it just rounded off the flutes without even scratching the wheel lock. I also tried heating the LUG OFF until I could see the metal turning red and then hammered it on the wheel lock, hoping to get a shrink-fit. No dice. I'm not sure what I am going to do now.
The flutes were already slightly worn when I tried the heat. Maybe if I tried the heat on a fresh LUG OUT it might work but I doubt it. Perhaps a higher quality tool (eg, Snap On) would he hard enough to bite into the wheel lock. I'll talk with McGard tomorrow.
Crap, I may have to cut the wheel away from the wheel lock. That will be an expensive repair!
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
The Internet is loaded with suggestions on how to do this. The most common one is to drive a 19mm socket (not a deep socket) onto the wheel lock. I did not want to do this! Didn't want to ruin a socket, didn't think it would work, yadda, yadda, yadda.
Well, I'm here to tell you that it worked like a charm. After removing the first lock, I was able to drive it out of the socket (the hardest part of the job) and reuse the socket on the second lock.
The Sears Lug Out WILL NOT work on McGard wheel locks. If anyone out there has experience which says otherwise, please let me know. The steel in the Lug Out is softer than, well you know what I'm trying to say.
Glad it worked out for you. Your approach was better than mine. I wasted money on buying 2 replacement keys from McGard only to use them to remove the locks to throw them away.
I guess I feel a little better about not having wheel locks now that I know a theif only needs a 19mm socket to remove them.
I'm assuming the dealers remove the factory installed lug nuts to install the wheel locks. I wonder what happens to those lug nuts? In hindsight, I wish I would have asked for mine when I bought the vehicle.
Roger, I know the Sears LUG OUT does work (or at least used to work) on some wheel locks. I discovered LUG OUT while reading another auto forum - I think it was either Mustang or Corvette but don't hold me to it. The guy was raving about LUG OUT. He showed pics of the LUG OUT package and pics of the wheel locks after they had been removed. The locks were badly deformed indicating pretty soft metal. OTOH, McGard locks are extremely hard and brittle. On my first frozen lock, a piece just chipped off the end. On the second frozen lock, a piece chipped off the end of the lock and the key broke as well. I will ask Sears for a refund because their warranty statement says complete satisfaction guaranteed. The LUG OUT package should say something like "will work on most wheel locks" or "will not work on hardened wheel locks".
They want $10-12 per at the two Toyota delaers closest to me. I can get them for $1.66 on-line or $3.99 from Advanced Auto. My concerns about aftermarket are the finish quality (ie corrosion resistance) and weight.
I did lok at them at one of the big auto chains (can't remember which one now) and what I did notice is that the washer could be removed. On the factory nuts it is a captive washer so no chance of losing it.
Most Toyota dealers have a universal Mcguard type set that will take off any of the security type lug nuts (my key was lost by the prior owner) They popped those puppies off in seconds, and didn't charge me a dime. it seems to me this woould work as the universal keys seem to bite in different areas where you have stripped it....
