Motor louder than usual!
Old 08-08-09, 08:14 AM
elacesar
elacesar's Avatar
Default Motor louder than usual!
Hello this is about my RX300 2001 with 115000 miles on it that runs great but all of a sudden the motor sounds louder that usual.. I changed the spark plugs at 80000 miles with the same iridiums and i have always changed the oil at 3500 miles intervals including the air filter. The car runs pretty good except for every once and a while it will seem as if the carb gets flooded and will stall for a second but then it runs fine.. Any help from you Pros will be greatly appreciated.. Thanks alo for any help..
Old 08-08-09, 11:08 AM
sktn77a
sktn77a's Avatar
Engine noise or exhaust/manifold noise?
Old 08-08-09, 11:09 AM
carguy07
carguy07's Avatar
Louder is usually an exhaust leak. The flex pipe is a good place to start. It seems the exhaust manifolds crack around the o2 sensor a lot too.
I would clean the IAC valve and see if the stalling goes away.
Old 08-08-09, 11:58 AM
elacesar
elacesar's Avatar
Thanks for the help I will check the exhaust area tonight but can you explain to me where the IAC valve is? I did clean the throttle intake area with carb cleaner and it is the same.. Thanks for the help
Old 08-08-09, 02:07 PM
carguy07
carguy07's Avatar
You are in the right area. You may need to take it off to get it loosened back up.
https://www.clublexus.com/forums/rx-...out-yours.html
Old 08-09-09, 06:40 AM
JohnLX300
JohnLX300's Avatar
From my experience with sudden engine being loud is, like carguy07 stating the flex pipe in the exhaust. This is the second car I have had with the flex pipe. I know from it happening to me. I was driving on expressway all of a sudden ..... loud exhaust....I thought it was some dinky car that I pulled up to. So when I tried to get away from it I couldn't. I looked under the car and I couldn't see the tear in the flexpipe. I had to stick my hand around it to feel the air coming out from the top of it blowing onto the engine. I did this, early one morning when the car was totally cooled so I could get a good feel before the exhaust heated up.
Old 08-09-09, 09:12 AM
elacesar
elacesar's Avatar
Thanks again and i did check the exhaust pipe right under the motor and the sound is coming from looks like a wire braid material.. Is this a difficult job or can a good handyman take care of this??
Old 08-09-09, 09:32 AM
salimshah
salimshah's Avatar
Received 1,057 Likes on 954 Posts
that is the flex(ible) connection. Replace or weld over. Proper fix is replace. Muffler/exhaust shops can do the job as they have the tools and equipment and lifts.
Salim
Old 08-09-09, 09:36 AM
elacesar
elacesar's Avatar
Thanks alot..
Old 08-10-09, 06:58 AM
JohnLX300
JohnLX300's Avatar
If this front pipe(with the wire braid), has never been replaced. Things can get a little tough with the rusted bolts. I did mine myself without any issues. I went to a muffler shop after I purchased the part and they wanted $200 to install and said it could cost more becsause of the rusted bolts. And this was the least expensive out of all the places. So I put the car up on two ramps, the hardest bolts to remove are the ones on that connected the front pipe assembly to the pre-cats. You "supposed" to have a torch to heat the bolts ups. So I turned the car on for a couple of minutes to heat the bolts up......and it worked, all the bolts came out with a little elbow grease. The only part I had to buy was rachet extensions so my tools would reach the bolts. Other than that, I took my time doing this and it took about an hour. hope this helps
Old 08-10-09, 07:40 AM
elacesar
elacesar's Avatar
Thanks alot Jone for the help and i am almost sure that i can do this but I think I will have a problem finding an exact fit.. Thanks again
Old 08-10-09, 08:11 AM
thomas1
thomas1's Avatar
My muffler shop did the whole thing for $100 including the parts....
Old 07-09-19, 09:31 AM
tiguy99
tiguy99's Avatar
Same here!
Just had this done yesterday on my wife's RX300.
So nice to have a quiet car again 😀
singleslam
13
11-14-16 06:33 AM
guccigirl
02-10-14 07:04 AM
garyatcp
GX - 1st Gen (2003-2009)
13
01-09-14 03:29 PM
ljtrumper
11-15-13 09:22 AM
hcfarm
11-15-08 01:26 PM
Quick Reply: Motor louder than usual!
