pcv valve
#31
I purchased an OEM PCV part number Lexus 12204-20040 and when I tried to replace the plastic PCV with the 90 degree angle with the new metal PCV I realized I could not install without removing the rubber bushing. Is this the correct way to install? I am hesitant to remove the bushing and try to screw in the new one.
#33
Be careful removing that bushing, its rubber and might be brittle to crumble in the cover. I am losing oil so I might install the newer valve cover with the screw on 90 degree pcv they both arnt the same. I know oil gets through my pcv. All I can think is there is a reason they changed the design.
Salim
