Need New Struts?
Just got my annual PA state inspection. Guy said I needed new struts. They aren't leaking but he said they "feel" bad and they have 97k miles and are "at the end of their useful life." My wife think the car drives fine - "just like new". I hardly ever drive it but it feels ok to me.
Questions: How many miles should I expect from my RX struts? How can I tell if they are bad? Should I replace all 4 or just the front? What is the safest tool to compress the springs? Thanks.
I've got 112K now, at about 108K when I got mine inspected they (Tire Kingdom) said they would need replaced next time around. When I took it into Toyota for the T belt I had them look at the struts and they said there were fine.
Super Moderator
I should probably take myself out of the equation here, because Mexico City was a rough place for just about any vehicle, but it took a fair number of years before the rear ones started creaking, but eventually a few bad bumps took out one of the front shocks. The only other time I had a shock go (in Mexico) was taking it up a nearby mountain.
Florida has been pleasant for my shocks though.
Art-When they tell you at annual inspection that they will need replacing is that a requirement or a recommendation? If it's not a requirement, I'd say 97k is a little early unless you have some bad roads back there. My DIL's seem fine yet at 133K but I should replace the front upper mounts one of these days. I worked 'em over before it went to Seattle and got rid of the noise, but that was 36k mi. ago and there is a little bit of return of the squeek, but they don't seem to be bothered by it. I would say how well they "eliminate shock" over bumps or fairly good challenges is as good a way as any. You can't seem to bounce a car with struts to tell if they're bad like you could shocks. I personally like the "2 finger on each end" spring compressor that HF did sell (don't know if they still sell that type or have changed design) It takes 2 per coil spring, but I think they came 2 in a set. I have had 2 sets of those for about 15 yrs. and have liked the very well. They're cheap and I used them in the shop for quite a few of those years. Much easier to handle than the big 1 piece unit.
Is this the HF tool? I saw a Lisle ( about $75) which attaches to the coil with U-bolts. I like this style because I don't think it coud slip. The HB shown in the link is the type i used before (I think) and it had a tendency to slip out of position.
http://www.harborfreight.com/cpi/cta...temnumber=3980
Don't believe everything that you hear. Just got back from the dealership yesterday with a laundry list of about 2k worth of "problems". I just fixed all of them for about 150 bucks.
Struts are pretty easy to fix if you are up to doing it yourself? Seems to be the way to go now-a-days. Be careful with the springs.
I hear yuh! Some of the compressors that are barely on there make me wanna jump every time I hear the slightest noise. Those things are nothing to mess around with, it's worth getting a good set that you can have forever.
Just bought the Lisle 62300 for $45 from Amazon w/free shipping. They retail for $58+ although I don't know why anyone would pay that much. They look substantial and have the U-bolt connection which I like. I have had good success with Lisle specialty tools over the years. I'll let you know how they look in person when I get them next week.
http://www.lislecorp.com/tool_detail.cfm?detail=1199
