PCV/CCV problems...
Old 08-19-09, 06:37 PM
jasonlp
jasonlp's Avatar
Default PCV/CCV problems...
My CE/VSC lights came on a few months ago. After taking it to the dealership, they said that it was cause by a loose gas cap, so they reset it. It's back again. This time they said it's from a "broken CCV valve nipple." I broke it... lol... The codes they pulled were; "P0440.P0441.P0446 EVAP" I think that's still from the gas cap? regardless, I need to fix this thing.
I know there are TONS of PCV Valves out there, and by the looks of it, none of them look like this one. Does anyone know where I can get a new one of these? I also thought about melting it back on there if I can't find the thing... It's from my Lexus RX300 (2001). Any help is GREATLY appreciated.
The Sticker says;
__________________
Toyota
90910-12227
184600-9110
12v
Denso - Japan (911)
__________________
Thanks guys!!!
J
Old 08-20-09, 11:33 AM
jasonlp
jasonlp's Avatar
Just got some plastic weld, and about to fix it myself. Thanks anyway guys! I'll post the process and results soon.
Old 08-20-09, 12:19 PM
salimshah
salimshah's Avatar
Received 1,082 Likes on 974 Posts
If you dig, you will find Lexmex picture post on the valve. Somewhere, there was a mention of metal barb instead of plastic [dont recall if the metal is new or old].
I would strongly suggest to buy the replacement from the dealer [or net dealer]. When it comes to sensors, best bet is to stay OEM.
Real thorough cleaning would be required if you plan to use epoxy.
Salim
Old 08-20-09, 12:59 PM
thomas1
thomas1's Avatar
I bet you could find a brass barb at hardware store then carefully JB Weld it in place (expoxy)
Old 08-20-09, 01:56 PM
mikey00
mikey00's Avatar
Looks like it's $45 if you want a new one search on part # at www.newlexusparts.com.
Old 08-20-09, 02:36 PM
jasonlp
jasonlp's Avatar
Originally Posted by mikey00
Looks like it's $45 if you want a new one:
http://www.trademotion.com/shoppingc...&siteid=213808
Didn't work for me?
for some reason the pvc valves that I have found online (maybe including this one) are the wrong type??? they all have one elbow, with no 2nd nipple (the part that broke on mine)...
Old 08-20-09, 02:37 PM
jasonlp
jasonlp's Avatar
I found a small set of fittings for vacuum tubing at the local auto place. Glued it in, waiting for it to dry. Super tight fit! hopefully it will work
Old 08-20-09, 05:11 PM
mikey00
mikey00's Avatar
Originally Posted by jasonlp
Didn't work for me?
If you go to www.newlexusparts.com and search on the Toyota/Lexus part number you provided, you will find the part for $45. The PCV valve is listed under another part number for less than $10 but looks nothing like it.
Old 08-20-09, 07:56 PM
jasonlp
jasonlp's Avatar
you the man. hope it's the right thing for 50 bucks. I guess if that part # matches it must be right? thanks again!
J
Old 08-21-09, 08:41 AM
UNOHOO
UNOHOO's Avatar
i checked out that site, although they do have some very cool accessories the actual oem parts seem more expensive than lexuspartsonline.com
Old 08-21-09, 10:53 AM
mikey00
mikey00's Avatar
You are right they do "seem" more expensive. But be careful and make sure you look at the final price. For example you can find a $110 part on newlexusparts.com that sells for $102 on lexuspartsonline.com making it "seem" cheaper. But shipping is free on over $100 at newlexusparts.com and can cost as much as $20 on a $100 part at lexuspartsonline.com. I haven't been able to find any one cheapest source of lexus parts over the years. You have to evaluate each individual part. I prefer and usually end up using Irontoad. But the hassle there is they don't have the online parts searching so you need to email for a quote.
Old 08-21-09, 11:41 AM
bob2200
bob2200's Avatar
I haven't purchased that much, but I just telephone them for the order. The parts guys have been very helpful on the phone.
Old 08-25-09, 05:48 PM
trhs75
trhs75's Avatar
Do you have a photo of where this part is on the engine? I don't recall seeing it, but the car's not here right now to look!
Old 08-25-09, 08:36 PM
salimshah
salimshah's Avatar
This is what search gave me:
https://www.clublexus.com/forums/rx-...pvc-valve.html
try pm Lexmex .. I think he had more pictures.
Salim
Old 08-25-09, 08:51 PM
trhs75
trhs75's Avatar
Thank you,Salim!
Quick Reply: PCV/CCV problems...
