Time for timing belt(s) on a 2002 RX300...Help
so........ it is past time to have the timing belts done on my 2002 RX 300
not really interested in going to ANY dealer....I just cant afford their pricing
how much have you paid & where in the LA area did you go for this & were happy with the result...??
any one have a good independant Lexus mechanic?
we are 10k past the 90k spec now & the wife is getting nervous so we need this done asap
PLEASE advise.... & THANK YOU
ed G.
ed G.
ed G.
ed G.
I had my '99 RX300 timing belt replaced at 105K miles. Cost was $262.95 at an independent. Also had water pump replaced for $181.95, spark plugs for $350, serpentine belt replaced for $78.48, coolant exchanged for $79.99 and power steering fluid exchanged for $40.
We turned down cabin air filter replacement for $76, transmission flush for $210, rear differential service for $53, transfer case service for $53, replace upper and lower radiator hoses for $160.
But when we got the car back it shifted funny. This was in March of 2008. When the transmission fluid was checked it was way over filled. This may have been the start of transmission problems for me which have now resulted in a rebuilt transmission. We never authorized the independent to do anything on the transmission so have no idea why they would have added fluid to it.
ed G.
ed G.
I would be among the few who says, you carry a risk if you dont change the belt. While most would say the risk is low (rightly so), but you would be on your own if and when the belt skips/breaks etc. If that happens, please do not blame the well meaning advice of the CL members. In my case, at 90K the idler in the belt train needed replacement. [it is not just the belt].
If you want to keep the vehicle, you will need to change it at 100k, 110k or 120k or what ever milage. If you sell your vehicle, you will have to make adjustment in price (very likely). It is not like that it will go away.
Salim
Salim
Salim
Salim
As an aside, it is my feeling from my experience in cutting all parts apart to inspect, that they should all be changed, but the aforementioned lower pulley is even a more important reason than the belt.
Is the RX300 engine an interference or non-interference engine? That will make a huge difference if the tb ever breaks on you. Mine is at 124k miles and never been changed.
I see you have a 2002 RX300. From what I've read on this forum, that is an interference engine. However, a Lexus mechanic has told me (for what it is worth) that it would do some damge but not trash the whole engine (like on some interference engines) if it broke.
supposedly the VVT-I motor (like we have) is an interference engine.The non VVT-I is not.
You're right. I have the non vvt i in my 98 camry xle which I've replaced. I'm about to purchase an RX 300 with vvt i (not aware of them coming without vvt i). I'm enjoying this forum, very similar to supramania.com (also have a supra) and there's good information here. Good luck and if it makes ya feel any better, if I buy this rx near me, I'll be changing timing belt tensioner, idler pulley, and timing belt -- if I pull the motor, then I'll be going further with it. ....Yay...
