When do coil packs fail?
Old 09-04-09, 01:12 PM
salimshah
salimshah's Avatar
Received 1,080 Likes on 972 Posts
OEM Spark plug gap ... I thought they are pre-gapped and any attempt to move them will break the gnd leg.
Thoughts? Opinions? Experience?
Salim
Old 09-04-09, 01:16 PM
lexus114
lexus114's Avatar
Salim
Thats what I always hear about them.
Old 09-04-09, 01:35 PM
Lexmex
Super Moderator
Lexmex's Avatar
Take a closer look at the gaps when you get new plugs and measure them. My uncle would always check the gaps of new plugs and he'd always find at least 1 or 2 for every set that weren't gapped right. My college roomate Mike had his plugs done for his Z06 Vette last year and 2 of the 8 were not gapped properly.
Old 12-17-12, 04:05 PM
soonerck
soonerck's Avatar
Will driving with a dead cylinder due to a bad co il do any further damage? or am I simply driving a 5 cylinder.
Old 12-18-12, 06:05 AM
Lexmex
Super Moderator
Lexmex's Avatar
Yes, because you would be dumping in raw fuel into the system. I could understand that if it happens in the middle of nowhere you may not have much choice, but generally you don't want to be driving on it any bit longer than you have to.
Old 12-25-12, 05:47 AM
toyo
toyo's Avatar
360K on my 01 with the original coils. Yes, i'm very lucky!
The ECM will not allow the injector to open for a particular cylinder if it is not detecting a spark. Just FYI.
Old 12-25-12, 10:00 AM
Lexmex
Super Moderator
Lexmex's Avatar
True, when it's dead.
The situation I had about 7 years ago, where it was sputtering, coil was still functioning, just not perfectly, and wasn't getting a complete combustion.
Old 12-25-12, 10:20 AM
toyo
toyo's Avatar
Wow. That is pretty rare. Usually when they go out, they are dead dead dead!
Old 12-25-12, 11:38 AM
Lexmex
Super Moderator
Lexmex's Avatar
Most do die. In my case, I had sprayed too much cleaner into the intake manifold and paid for it a few hours later with the coil issue. We actually tested it by hooking it up (at arms length) and watched it spark...not spark....spark, but then tried it a bit later and it had died, but we never started the vehicle up until we got another coil (actually had to use a modified Camry coil in Mexico until we could get the one for the RX300 from the U.S. since no Lexus south of the border).
When I came back to the U.S., I did have a P03XX codes come up with a flashing CEL (obvious coil issue), and hesitation and then it would go away (both the hesitation and the light).
Old 05-21-17, 09:13 AM
dubsta1
dubsta1's Avatar
208k & i just replace 1 & 3 today
PortAh
05-20-19 12:27 PM
Goldenbear
ES - 5th Gen (2007-2012)
05-06-18 11:47 PM
rockyvo09
10-21-14 08:04 AM
SorrGwa
12-04-08 07:23 PM
Quick Reply: When do coil packs fail?
