Fault code on my 1999 Lexus RX300
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
The car was bought by me at year 2005 and until now it is still in excellent condition.
Few days past, my Check Engine Light on and went to a workshop for a scanning, the result was as below.
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
P1130 - Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 1 Sensor 1)
P1133 - Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 1 Sensor 1)
P1150 - Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 2 Sensor 1)
P1153 - Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 2 Sensor 1)
P1346 - VVT Sensor Rang/Performance Problem (Bank 1)
the workshop told me that the P1346 VVT sensor might be my timing belt have loosen and should be replace a new Tensioner and Timing Belt, is it true?
and may I know where is the Air Fuel Sensor located for the above code? I didn't face a problem at my lovely Lexus before, and I hope Lexus fans here could give me a hand on this problems. Thanks a lot!
i love my Lexus, from owning, now and after!
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Other members will surely comment on the codes you are getting and interpret them.
Can you tell us how many miles you have on your current timing belt?
Has any work been done recently ... within a week before the CEL came on?
Salim
Salim
I currently having a 112 miles on my RX300, as I know it is time for a changing of timing belt. Also recently I didn't done anythings before and the CEL light on since past few days. The CEL will goes off everytime after I turn off my vehicles and will be light on after a few second after the car start driving. The problems is I unable to located the Air Fuel sensor that listed above and I can't try replace it as well.
Edit: Oops, I see you already said you have 112 (I assume you mean 112,000) miles. I am very surprised that you are having any TB issues at this low mileage and I would be very surprised if your tensioner is bad. I'll sit back and let the experts chime in but something is sounding a little fishy here.
I delete all the OBD Fault code since that day when the CEL light on and it is back with these code again after I start driving my vehicles leaving the workshop.
Lexus fans, please give me a hand here. Thanks!
Thanks a lot Lemex, the photo that you post has clearly show out where the Sensor located. I will try to replaced it this weekend by myself. Thanks a lot!
I will post my feedback when I settled this code.
Super Moderator
If you have already have the sensors, then go ahead and change them. However, I'd have the timing belt changed out/examined first as that is usually the root cause of the two A/F sensors having a CEL
Thanka Lexmex, I have repalced a new timing belt set today. The VVt Sensor CEL has go off and I deleted all the ODB codes.
But the A/F Sensor came on after 4 or 5 miles after I start driving my car just now.
May anyone know what is the A/F sensor part number for B1S1 and B2S1?
I think that maybe one of the sensor need a replacement but the workshop told me that usually should change one pair of it. Otherwise the second sensor will light on in future due to unbalanced reading from sensor. Is it true? Thanks!
I replaced only one of my A/F sensors a couple years ago and have not had any problem. I would not replace both unless you need both. After you replaced timing belt, did you get codes for just one A/F sensor?
Super Moderator
When my a/f sensor really goes, I will change the other one at that time, but I may as an example to the forum monitor the sensors via a diagnostic program to show what is really going on numerically. It is possible for the offset between new/old sensors to cause an issue, but not a strong likelihood.
It's important to stick to the OEM Denso sensors, as we have had issues with people not using the sensors and running into issues. The Denso number is 234-9009.
2 weeks ago my check engine light and VSC light are on @ the same time. I brought it to Autozone pulled the code P1130 & P1150. I ordered both Denso sensors 234-9009 for 275 shipped. On Monday Sept, 7, when I re-fuel at Holiday gas station and started the car, the light cleared by itself. I went home and checked the gas receipt; it was re-fuel @ SA gas station so it might be a bad tank of gas.
