Change wheel bearing or hub as well?
Hi everyone,
I have a 2001 RX300 AWD and the rear right wheel bearing needs to be replaced. Should I just replace the bearing or the hub as well? The bearing needed to replaced a year ago actually just never had the time to do it.
Thanks
Thanks
Is there any thing wrong with the hub? Has it gone bad due to bad bearing.
Salim
Salim
Look for visual damage and then at time of assembly double check the fit.
Salim
Salim
sivikvtec
Suspension and Brakes
03-13-10 06:51 PM
